Results 1 to 7 of 7
Thread: HQCT-e
    cheap custom title JC-S60's Avatar
    Mar 2004
    Ghent - Belgium
    HQCT-e
    If anyone is interested in pictures, see http://direct.xtronic.be
    Joachim
    Dec 2006
    Dam a very nice module. I need this soon. If I am running 3 y adapters to a 5 channel amp from front, rear and sub speakers, how would I get sound to the motherboard from this item, I assume there is a lineout somewhere on it to input into the motherboard or linein on a sound card correct? I also see the rca inputs on the side, but how are you able to run rca inputs for specific programs? GPS outputs thru soundcard just like all other programs that make sound. Is there a way to specify where you want gps to go?
    Mar 2004
    Ghent - Belgium
    @mchuang
    For your situation, you would just run a cable from the line-out to the line-in of your mainboard.
    The different line-inputs are for external devices (optional) like a car-kit or navigation device, not for different programs.
    Joachim
    FLAC SFiorito's Avatar
    May 2004
    when will mp3car.com be having these?
    Mar 2004
    Ghent - Belgium
    As soon as they order them... Diogenes (from Datalex, who makes these radios) is the one who will deal with mp3car.
    mp3car.com and Xtronic are the only two companies that can buy these tuners directly from Datalex.
    Joachim
    p.s. thanks for the nice tutorial on EWF, minlogon etc... great info and I was meaning to say thanks for a long time already!
    Sep 2006
    Is there a document that describes the functionality of all the inputs/outputs on the unit?
    Mar 2004
    Ghent - Belgium
    Quote Originally Posted by Miraz View Post
    It has
    1 stereo line-in
    2 mono line-in
    double stereo (front/back) line-out
    12v input
    2 "activation" inputs where you can put 12v on and do something in software depending on the state of that input (on or off).
    Antenna is SMB, with an adapter available to motorola.
    USB is an USB-B receptacle, use a standard USB cable.
    Hope this enough info,
    Joachim
  1. HQCT Driver.
    By TheLlama in forum Linux
    Last Post: 10-06-2009, 10:32 AM
  2. HQCT problems
    By Roadwarrior in forum General Hardware Discussion
    Last Post: 01-24-2009, 04:24 AM
  3. HQCT seek down problem
    By DrLove in forum Road Runner
    Last Post: 12-29-2006, 05:14 AM
  4. VoomPC Ampie Case and HQCT module
    By mcfennek in forum General Hardware Discussion
    Last Post: 07-16-2006, 05:16 PM
  5. HQCT upgrade advice/help needed
    By NeoMatrixJR in forum General Hardware Discussion
    Last Post: 07-07-2006, 03:25 PM
