Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Help, 2 way switch + LEDS
  1. #11
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Quote Originally Posted by dhantiflag View Post
    what size diode should i get?
    sry i didnt see that before....
    A 3 gronkel diode is best, but failing that a 1 splurget diode may just do. If you get the splurget diode, make sure it is a vertical and not a horizontal. Red diodes are best, but they cost more.
    Basically your question amounts to "how long a piece of string should I get?" It totally depends on the application. They're your lights, you should know how many there are and how much current they draw. Get a diode that can carry enough current, and reverse breakdown voltage that can handle the supply voltage backwards.
  2. #12
    DIGItonium
    Guest
    How about he use another LED so when it lights up, it's a good indicator the circuit is working.
    Heh... you need a 3-state mechanical switch of some sort.
  3. #13
    Variable Bitrate dhantiflag's Avatar
    Nov 2006
    Mentor, OHIO
    thanks rob, i got it working :-)
    the diode worked perfect!
  4. #14
    Nov 2006
    Mentor, OHIO
    well here are some pictures of what i started....
    next is under the driver/pass leds :-)
    i got a little bored :-P so what...
  5. #15
    Dec 2007
    Don't know if you still need this, but all you'd really need to do for this set up is get a switch that has 2 prongs for each setting (all the ones I have do?) and it should work no problem.
  1. help with micro switch
    By blackcar in forum Hardware Development
    Last Post: 05-21-2006, 12:50 PM
  2. New product - PC Power switch with wired remote
    By hd54321 in forum General Hardware Discussion
    Last Post: 03-08-2006, 11:48 PM
  3. Car Window Switch Replacement
    By alienjj in forum Hardware Development
    Last Post: 09-05-2005, 01:08 PM
  4. Need help with X31 port replicator power switch
    By viguera in forum General Hardware Discussion
    Last Post: 06-22-2005, 12:12 PM
  5. Savage Switch Botton Group Buy via UK's Iconstyling.com....
    By TheBigDog in forum General Hardware Discussion
    Last Post: 07-21-2004, 11:51 AM
