Results 1 to 10 of 15
Thread: Help, 2 way switch + LEDS
    Variable Bitrate dhantiflag's Avatar
    Nov 2006
    Mentor, OHIO
    please let me know about the picture below. :-D!
    Maximum Bitrate psyrex's Avatar
    Jun 2005
    Oakland, CA
    Well, how many discrete steps do you need?
    1) all off
    2) 1 led on
    3) 2 leds on
    4) 3 leds on
    If you want each of those steps to have their own control, you need as many throws. Probably a rotary would work for you?
    Gen 1: Pentium 3 1GHz - ATX - 2005
    Gen 2: Pentium M 1.6GHz - ITX - 2006
    Gen 3: Pentium M 2.0GHz - 5.25" SBC - 2007
    Gen 4: (coming soon: Core2 Duo - 3.5" SBC - 2009)
    ...it never ends
    Nov 2006
    Mentor, OHIO
    well what im doing is, putting LEDS in my cup holders and under my dash by my feet n passanger....
    so what my goal was, to be able to have either cupholders on, or have under dash, or have all on....
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Quote Originally Posted by dhantiflag View Post
    3 options, 2 way switch. Given that the switch can only be in two positions, in what position would you expect the switch to be for each of the 3 options? 3 into 2 doesn't go.
    Nov 2006
    Mentor, OHIO
    Well, since it was a two way switch, what i was going to do, is either A) everything off, B)Cup Holders only, C) Cup Holders + Under dash
    this is what my orignal goal was
    Apr 2000
    Bedfordshire, UK
    That's not what your previous message says. Please stop changing the specification.
    Although you still have three options here, since one option is everything off you can achieve this with a centre off 2 way switch and a diode. Similar to your first diagram but with a diode between the outer terminals.
    Nov 2006
    Mentor, OHIO
    Quote Originally Posted by Rob Withey View Post
    sorry dont mean to keep changing...
    it is what i last said..
    now the problem i have here, i know how to make the diagram i have above, the only problem is, i dont know how when i want all to turn on how to achieve that...
    Nov 2006
    Mentor, OHIO
    Like ok, so the switch has the settings, Switch1, switch2, and off
    if i have switch1 set to two leds, how to i set switch2 up so it will go to those same 2 LEDS plus addition LED without coming on when switch1 is activated.
    Apr 2000
    Bedfordshire, UK
    Nov 2006
    Mentor, OHIO
    what size diode should i get?
    sry i didnt see that before....
  1. help with micro switch
    By blackcar in forum Hardware Development
    Last Post: 05-21-2006, 11:50 AM
  2. New product - PC Power switch with wired remote
    By hd54321 in forum General Hardware Discussion
    Last Post: 03-08-2006, 10:48 PM
  3. Car Window Switch Replacement
    By alienjj in forum Hardware Development
    Last Post: 09-05-2005, 12:08 PM
  4. Need help with X31 port replicator power switch
    By viguera in forum General Hardware Discussion
    Last Post: 06-22-2005, 11:12 AM
  5. Savage Switch Botton Group Buy via UK's Iconstyling.com....
    By TheBigDog in forum General Hardware Discussion
    Last Post: 07-21-2004, 10:51 AM
