Results 1 to 2 of 2
Thread: Programming Clifford Alarm and Door Poppers, I Need Help!
    Feb 2007
    Hi! I have a Clifford Intelliguard 8000 installed on my car. The door poppers are connected with the alarm, so all I have to do is press certain buttons on the clifford pager to open a door of my choice. My problem is that both of my back doors are not opening, I am 100% sure they lost the programming. I was wondering if anyone knows how to program the two back doors. What I need is to turn on the channel which operates the back doors. I have a channel extender on one of my back doors. The way I open the door with the clifford pager is: I press the side button twice and then I press the starter button( a.k.a, the button with the asterik, or a.k.a button #4, or a.k.a the button all the way to the left). This would open my back left door, now to open the back right door, I repeat the same sequence again a second time(this is using the channel extender). I would really appreciate anyones help, If anyone knows how to program that channel, so it can send the signal to the solenoid in order for it to open my back door that would be great. Thanks!
    Oct 2006
    Las Vegas
    Pressing the LevelShift button twice shifts the buttons to level 3 (channels 9–12). Pressing Button 4 within 7 seconds sends channel 12, which is unassigned for the Intelliguard 8000. What other accessory (model of what you call the 'channel extender') was installed on your vehicle? Your vehicle info would help as well. My help can only go so far, as I don't have any clue how they actually hooked it up. Someone with greater authority might want to move this to an appropriate section. Perhaps the12volt.com.
    It's been a while...
