+ Reply to Thread
Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: To those who have implemented tuning on the PC
    _
    Mar 2004
    Little Elm, Texas
    I have a few questions for things I'd like to add to the FAQ. I've had a LOT of people PM me asking me questions. Since I haven't implemented this in my own vehicle yet, I cannot answer. Some of these questions don't really have an answer anyways, but maybe collectively we can come up with some good guidelines.
    • What's the minimum processor speed needed to run audio tuning software?
      • For a fully active set-up with pay-for software? (I mention these options because the pay-for and the free software tuning seems to be different in terms of intensity)
      • For a fully active set-up with free software?
      • For a 2-way set-up
      • For a 3-way set-up
      • For a 5.1 set-up
    • What sound cards work for this project?
      • For a fully-active with pay-for software?
      • For a 5.1 set-up
    While I completely understand that the minimum processor requirements will vary greatly depending on your set-up and how detailed you want to get with tuning, perhaps we can give people a minimum overall?
    I'd also like to ask anyone who has fully implemented tuning in the car to list off their hardware specs and the software they are running. Maybe this will help others that are trying to get started in this game.
    I'm also wondering if another sub-forum just for tuning on the CarPC might be a good idea since there's so much information involved with it. Your thoughts?
    Jan Bennett
    Mar 2007
    I can give you a computer speed that I have tried and does not work..
    VIA C7 1.5GHz
    It's a popular chipset and I am sure many have wondered about this.. so there is the answer.
    The soundcard that I did get to work is the
    Presonus Firebox. http://www.presonus.com/firebox.html
    This was with fully active VAC, and the free versions of Console and ASIO4All.
    I used a multimeter to measure the Signal voltage of the firebox. I got between 5-7 volts before clipping. If I recall correctly, Up to 10 -13 volts clipping. It has six ouputs, one headphone out, 4 inputs and can be powered through firewire. Pretty decent card for software ASIO based tuning.
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by ironfinger View Post
    VIA C7 1.5GHz
    Thanks for the info! However, can you please elaborate on which method did not work and on what you were trying to achieve exactly? Is it what you have listed below?
    Also here, can you give us some insight as to what the rest of the harware was that worked with this set-up? How many channels were you running, etc.?
    Jan Bennett
    Mar 2007
    The via 1.5 chipset could not handle the winamp/VAC/ASio4All/Console approach. this method: http://www.mp3car.com/wiki/index.php..._Tuning_Method
    I tried running 5.1 channels in Console.. with only EQs plugged into the fronts, center, rears, & sub; no crossovers or time alignment, just 30 band EQs. As soon as I hit play, 75% of the processor was consumed.. chug-a-lug!
    The Presonus Firebox worked with the above setup.. but the computer just was not powerful enough. If I had a powerful cpu, I am positive that this sound card would be most excellent. However, it's a soundcard that is taylored towards the recording studio, so while it will work great for the above method, there are better and cheaper options for a stand-alone setup.
    Low Bitrate BenOBS's Avatar
    Aug 2006
    QC/CA
    Hardware:
    Mini ATX M2NPV-VM + Athlon X2 4200+
    Audigy 2 ZS
    Opus 250w
    Software:
    Foobar
    KX Project
    Console
    AIXcoustic Electri-Q (full version)
    Voxengo AudioDelay
    Right now its driving a 5channels fully active setup.
    Electri-Q is used for crossover and tuning. Right now, it is only loaded 3 times, 1 for tweeter, 1 for mid-woofer, 1 for sub-woofer. It will probably be loaded 8 time in the final 7 channel setup. 3 Audio delay are loaded too but dont seem to use lot of power.
    In standard mode (analog or digital), not in eco mode, console will use around 7-8% of the cpu. In Linear IIR (The one i use right now), it will be around 30% (i think everything is processed twice, so this is why it is so hungry).
    Routing and master volume is done via the KX Project. Foobar use kernel streaming to output data to KX and KX record it in Asio for console. The resulting 5channels from console are connected to master volume then jack output.
    Foobar play stream in 24bits and resample to 48000hz in high quality.
    Carputer Athlon X2 4200+
    800tsv - Audigy 2 ZS - PowerMate - Wifi 802.11n
    All Audio Tunning done via Software. 7 channels.
    CDT ES-07 - HD2 - DRT25
    ED Nine.2x
    ED Nine.4
    ED Nine.1
    ED 110v.2 (x2)
    _
    Mar 2004
    Little Elm, Texas
    BenOBS - since you have implemented KX drivers tuning and are using Foobar, would you mind contributing?
    Have you implemented Foobar Player Audio Processing
    http://www.mp3car.com/vbulletin/car-...rocessing.html
    It would be greatly appreciated!
    Thanks!
    Jan Bennett
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    Here is my setup, I'm kind of a cheapo person, so I didn't opt for top end computer hardware until I felt I needed more.
    Hardware
    -Intel mATX D865GVHZ mobo
    -Pentium 4M 1.8GHZ (Socket 478 laptop processor)
    -512MB PC2100 RAM
    -Audiotrak Prodigy 7.1 HIFI
    -Seagate 7200RPM 3.5" harddrive
    Software
    -Directwire (Routing WDM stream to ASIO)-came with my soundcard
    -Console (Full pay version)
    -Frequency Allocator (Full pay version-not the lite full version)
    -One of the free 31 Band EQ's listed on wiki page-one for each left and right channel before going into frequency allocator-so 2 instances
    -Voxengo Stereo Delay (4 instances)
    -Winamp
    8 channels or a 4-way stereo setup.
    -Tweeters
    -Midranges
    -Midbass
    -Subwoofer
    I was seeing approximately 50% CPU usage with my setup. I'm probably going to switch my EQ to the ElectricQ free one. I am also aware that ElectricQ can be used for EQ AND crossover, but I think I will stick with frequency Allocator since I already bought it, and it's a little easier to use for setting crossover points.
    Sep 2006
    Constant Bitrate Lazyflip's Avatar
    Mar 2005
    FL
    Quote Originally Posted by RedGTiVR6 View Post
    I vote yes for another sub-forum just for tuning on the CarPC. I'm slowly starting to save up some money to go active and I'm trying to acquire more knowledge on the subject.
    Oct 2004
    NY
    I'll second that, one forum for general car audio & another for high end & pc tuned audio would work well I think, there are some guys that just want to get sound out of there pc, & then theres the real diehards who know sound is just noise & want an audiophile solution... seperating the 2 sounds like a worthwhile thing I think
+ Reply to Thread
  1. FS - Assorted Car Pc Parts
    By OriginalNick2 in forum Classified Archive
    Last Post: 06-23-2006, 07:41 PM
  2. VIA and Mini-box Announce First Sub-$300 Car PC Kit
    By Goofus in forum General Hardware Discussion
    Last Post: 03-13-2006, 12:28 PM
  3. FS: CarPC 2.4 startup/shutdown controller
    By evilragu in forum Classified Archive
    Last Post: 03-05-2006, 05:28 PM
  4. first car pc project
    By machineshop in forum Newbie
    Last Post: 12-15-2005, 04:17 PM
  5. basic car pc idea
    By Joseph in forum Newbie
    Last Post: 11-08-2004, 03:04 PM
