Page 4 of 10 FirstFirst 12345678910 LastLast
Results 31 to 40 of 94
Thread: Behringer DCX2496 -- dc power supply
  1. #31
    Maximum Bitrate Dennis5587's Avatar
    Nov 2004
    NY
    my god... this is the biggest manual I have ever seen
    2006 Mazda 3
    Behringer DCX-2496
    JL500/1 JL10w6v2
  2. #32
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    have you tried the software? it's pretty cool/simple
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  3. #33
    Nov 2004
    NY
    no not yet... All I had last night was my mac
    edit: the software is good, makes things a lot easier. You can change parameters on the unit as well which makes it nice, two options to tune. I havn't been able to try everything but I do like the EQ, seems able make tuning a lil easier and very precise
    2006 Mazda 3
    Behringer DCX-2496
    JL500/1 JL10w6v2
  4. #34
    _
    Mar 2004
    Little Elm, Texas
    6 analog outputs.....damnit!
    need 8...at a minimum...
    Keep us updated on this guys. Looks very promising for those who need fewer analog outputs.
    Jan Bennett
  5. #35
    Dec 2004
    Los Angeles Ca
    you can link more then one unit together :-)
    12 analog outputs is easy to attain :-)
    M10k
    My Car Pc Install
    My Boat Pc worklog
  6. #36
    _
    Mar 2004
    Little Elm, Texas
    at that point though, price is no longer really an issue as it's more in the range of the DBX and size is a big concern...
    Jan Bennett
  7. #37
    Dec 2004
    Los Angeles Ca
    from what i've read there isn't a lot to the insides so you can condense it pretty efficiently and it also doesn't need the front panel to be hooked up to function properly. but i dont know a lot about the dbx so i dont have much to comment about how they compare
    M10k
    My Car Pc Install
    My Boat Pc worklog
  8. #38
    _
    Mar 2004
    Little Elm, Texas
    If there are any pictures of the inside of this thing I'd be very interested.
    The front panel is not necessary at all for operation?
    Jan Bennett
  9. #39
    Dec 2004
    Los Angeles Ca
    not needed if you control it with the computer :-).
    i'll look for pics
    M10k
    My Car Pc Install
    My Boat Pc worklog
  10. #40
    Nov 2004
    NY
    I'll take pics when I go home, the inside is virutally empty, there is just the power supply, which we swap out, the front pannel, which is most of the space, the rear pannel, and a small board for processing inside. You only need 3 of these 4, 2 of the 3 connects useing a ribbon cable, and the only other connection uses wires for power. Totally downsizeable.
    On the downside, my amp is messed up JL 300/4 amp
    edit: You could also relocate the front panel to a more convienient spot... but it would be tricky splitting the panel up
    2006 Mazda 3
    Behringer DCX-2496
    JL500/1 JL10w6v2
  1. FS: 250 watt DC to DC Power Supply
    By EsKALad in forum Classified Archive
    Last Post: 11-11-2005, 08:58 PM
  2. Replies: 0
    Last Post: 02-09-2005, 03:49 PM
  3. Replies: 7
    Last Post: 06-15-2004, 10:29 PM
  4. Replies: 8
    Last Post: 11-04-2003, 12:03 PM
  5. what is the cheapest DC to DC ATX power supply available?
    By Squeezer in forum Power Supplies
    Last Post: 07-29-2002, 02:17 PM
