Page 7 of 10 FirstFirst 12345678910 LastLast
Results 61 to 70 of 94
Thread: Behringer DCX2496 -- dc power supply
  1. #61
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by envisionelec View Post
    Sure, if you can get 9V in (at 0dB)! I've not yet seen a headunit that can do this (no matter what the screen printing on the faceplate says).
    Hi Volt heads are great if you need them. Problem is - 2V heads work just fine if your downstream equipment is any good.
    sorry to ask so many questions; but say we're going s/pdif into the behringer... what's the output voltage? I'm not overly worried about it since my amps have balanced inputs so induced noise is less of an issue for me, but it would be good to know
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  2. #62
    Sep 2007
    Quote Originally Posted by RedGTiVR6 View Post
    head unit...what's that?
    Ah geez. Right. That's like talking about Jesus in a Buddist temple. Or the Browns in Cincinnati. Whoops.
    So, you guys could help me with the in car computer stuff? My closest connection for this was building a, "biscuit PC" power supply (before they were plentiful) back in 1998 for my brother's MP3 player he built for his ride. His rig of a power inverter was unreliable and he always forgot to turn it off. I built the supply on a piece of perfboard and rewound the transformer from an old car amp. It was a little electrically noisy, but worked fine.
    He then bought the indash eMPEG Rio(?). I think he still uses that...
  3. #63
    _
    Mar 2004
    Little Elm, Texas
    heh - yeah - we might be able to help with that...lol
    Jan Bennett
  4. #64
    Sep 2007
    Quote Originally Posted by scott_fx View Post
    Uh, that would be as high as you want. To around 9VRMS before clipping. Way overkill if you ask me.
    on a different note...you will only have the voltage out that you put in...so say I go with the Hippo HiFi USB DAC...which only has something like .5v output...means I'll only have .5v out to of the Behringer to the amps, correct?
    If your amp can accept a 0.5V input with acceptably low noise, then there is no problem. You can increase output gain of the Behringer somewhat, but at the expense of noise. I'd build (or buy) a high end preamp before the Behringer is there was a significant problem.
    It's only 0.5VRMS Max? That is lower than line-level.
  5. #65
    Sep 2007
    Good, because I'm a computer genius. Right.
  6. #66
    Dec 2004
    Los Angeles Ca
    meaning that this is a car computer site... no head units
    edit..woops sloooowww on the draw on this one!
    M10k
    My Car Pc Install
    My Boat Pc worklog
  7. #67
    _
    Mar 2004
    Little Elm, Texas
    well, a quick search tells me it's actually 4.1v but I'm double checking that right now.
    Jan Bennett
  8. #68
    Dec 2004
    Los Angeles Ca
    hmm.. well what is the best way to figure out the best out how to set your gains. do you set the behringer close to 9v but not clipping and set the amp's gain low, or do we set the behringer low and turn the amps gain up?
    M10k
    My Car Pc Install
    My Boat Pc worklog
  9. #69
    _
    Mar 2004
    Little Elm, Texas
    I would set it to where you can set the amps at the lowest gain. This will allow the amps to run most efficiently.
    Jan Bennett
  10. #70
    Dec 2004
    Los Angeles Ca
    I would agree with you but i'm just wondering if the gaining at the amp would be cleaner since the amp is built to much higher standards then the dcx (i am assuming here)
    i guess i'll just have to test it
    M10k
    My Car Pc Install
    My Boat Pc worklog
  1. FS: 250 watt DC to DC Power Supply
    By EsKALad in forum Classified Archive
    Last Post: 11-11-2005, 08:58 PM
  2. Replies: 0
    Last Post: 02-09-2005, 03:49 PM
  3. Replies: 7
    Last Post: 06-15-2004, 10:29 PM
  4. Replies: 8
    Last Post: 11-04-2003, 12:03 PM
  5. what is the cheapest DC to DC ATX power supply available?
    By Squeezer in forum Power Supplies
    Last Post: 07-29-2002, 02:17 PM
