The x-volver has to be loaded up like the instructions on their page. You pick the impulse file that matches your sampling rate and load it into x-vovler. X-volver will not reload this file during a full startup shutdown, you must use hibernation or suspend.
The Mosc experimental one does not need the impulse file. Download the Left Right track on his website and play that on repeat to determine the spacing between the speakers that gives you the widest width possible. For distances less than 2M it's going to be less. In my car, the L&R speakers are almost touching. There isn't really any adjustment with his plugin. For right now, I'm using Time delay to account for off-center seating-but this is not optimal solution yet but it's still pretty good.
If you follow his block diagram however and build it using Voxengo Delay and Flipper.dll (180 inverter), you can make it somewhat adjustable. 0.06ms-0.12ms, depending on the spacing.
Audiomulch allows you to use the RACE version and adjust it.
Experiment with this in the house before trying it in the car so you know how it should work.
This is speaker-binaural.
LinkBack URL
About LinkBacks
If you have no center console or can construct a new center console that could work. Most people are too lazy or not adventurous to attempt something like this. The best cosmetic way would probably involve rebuilding or constructing an entire new dash.
