So here's what I'm thinking:
The output of the player - in my case CF - needs to be set to 1010LT SPDIF.
I getg no audio when I set it to SPDIF. I get audio on 1/2 when I set to 1010LT 1/2 OR 1010LT Multichannel. This makes me think that my path is broken after the 1010LT SPDIF - namely, in the Console/plugin area.
I haven't found any descriptions of setting up these plugins.
Here are my settings:
M-Audio CP:
Mixer tab, SW 1/2, 3/4, 5/6, 7/8 all muted. Under this tab, the Master channels are showing signal, and the SPIDF Rtn is showing signal. I have those sliders set to 50% or now.
http://farm6.static.flickr.com/5283/...49fa886287.jpg
http://farm6.static.flickr.com/5125/...e42fccc021.jpg
Input tab, nothing muted, all maxed, no signal seen.
http://farm6.static.flickr.com/5043/...8f744e0c94.jpg
Output tab, all maxed, no signal seen except SPDIF out. All channels set to "SW Rtn".
http://farm6.static.flickr.com/5202/...e2e3a78f54.jpg
If I change Ch 1/2 to "Mixer", I get signal in it. But I can't get signal on the others - 3/4, 5/6, and 7/8 don't offer the Mixer input option, and I can't get signal on them if I slave them all to 1/2 either.
CF 3.x:
If I go to Settings>Advanced>AudioVideo, scroll to Music Sound Device, and select 1010LT Multichannel, I get sound on 1/2 only. If I select 1010LT SPDIF, I get no sound. If I select 1010LT 1/2, I get a hotter signal on 1/2 than I do with Multichannel.
http://farm6.static.flickr.com/5165/...ed3c7fe3_z.jpg
Console
Preferences: Driver, ASIO. Device, M-Audio ASIO. Channel config, only 11/12 in enabled for now, and only 1-8 out enabled.
http://farm6.static.flickr.com/5128/...6c6c08ed_z.jpg
Here is the opened file from the original install:
http://farm6.static.flickr.com/5165/...8f968bae_z.jpg
TIA for any insights!
