It would look really ugly if you just stuck a speaker on top of the dash. Depending on your skill, maybe cut out a hole in the dash to mount a speaker flush, then put a cloth grill over it?
I need some help picking a center channel speaker and seting up my 5.1 please.
I haven't been able to find any info on what people are using for their center channel. I know there are single DIN center channel speakers out there but those won't work in the space (or lack of) that I have available. I am wanting to put a single, maybe 5.25" speaker in the middle of the top of my dash. But where can I get just one speaker?
Also, I am running an Alpine PXA-H700 processor and the center channel will be powered by a channel off my Alpine 4 channel amp which I believe is 40w RMS. The alpine only has one RCA out for the center channel since it is mono, this is also true for the sub. Do I need to have a Y adapter for this or do I just use one channel of the RCA cable and only one channel on the amp?
I think that's all for now. Thanks for any and all help!
hehehe, sorry, I guess I wasn't very specific about that. I am building a completely custom dash and the speaker most definitly won't be just sitting there.
I would check E-bay for a half set component speaker as just a driver will not get you the sound you want. I would probably be interested in selling a scanspeak 6" driver and a Focal Titanium 1.25 tweeter...
Epia M1000 1.2gig, Toshiba 40gb HD, Itronix 60gb HD, 512ram,PCR, Audigy2zs, 2 Xenarc 7" , FRODOPLAYER Trying RR frontend , 2@1600/w Harrison labs amps & Caps, Focal & MB-Quart midrange, Diamond Audio D6 Subs, Mb Quart Tweets, 2-Audiocontrol three.1 !
What would you be interested in selling it for and what kind of wattage can it handle? And do you have a crossover for them?
I still need to know how to wire it up though. Would I just use one channel of an RCA cable into one channel of the amp or will I need some Y adapters?
Thanks,
Brandon
