Results 1 to 10 of 14
Thread: 8 channel sound card control thru software?
    May 2008
    So I'm wanting to take a 7.1 sound card to get 8 channels out and configure it thru software as such:
    Output 1: Front L/R
    Output 2: Rear L/R
    Output 3: Subs (pair)
    Output 4: Center (one center)
    I haven't purchased the sound card yet. Is there a card and software program that will allow me to control my output signals independently and essentially provide a 5.1 sounding environment from a DVD on a 7.1 card? Basically, I have a pair of subs that I would like to provide signals independently and have a 5.1 surround sound field. I'd rather not split the output to my sub amp... Possible?
    FLAC WuNgUn's Avatar
    Sep 2007
    AudioMulch with ASIO drivers and you should be good to go!
    I haven't configured mine to use a 5.1 input signal (digital?), so I'm afraid I can't help you there...
    I just use stereo L/R input for Front L/R, Rear L/R, 1 sub and a pair of VU meters.
    Jan 2009
    what is a vu meter? and why do you need one?
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    Quote Originally Posted by summer69guy View Post
    What is VU-Meter? LINK
    Aug 2009
    Quote Originally Posted by acex008 View Post
    Output 1: Front L/R
    Output 2: Rear L/R
    what are FR/FL/RR/RL output? i am very confusedˇˇˇ sorry, i know a little about the output and input..
    Elsewhere
    Quote Originally Posted by Vengaemilio View Post
    FR = Front Right
    FL = Front Left
    RR = Rear Right
    RL - Rear Right
    How about the Wiki?
    Jan 2008
    vu meters would be used to verify that you have a good signal level in the software, esp when your speakers aren't working, or you have the wrong outputs hooked up in the software.
    Wungun has used audio mulch for a while, so he is just as biased as i am when i say to try out Console, asio4all, and Virtual audio cable.
    just as a note, i have not been very successful with cards with asio drivers built in, although it could just be me... asio4all would allow you to use wdm drivers in a program like console, or audio mulch.
    although i have not tried surround sound, so i can't help you very much there either-- though if you are interested in stereo upmixing, try spatmixer--i have not tried it, but should allow you to upmix a 2 channel source to 7.1(google says up to 12 channels output).
    also why are you interested in stereo subs, and surround sound? it would be easier, to have a mono sub output, you will experience louder(and possibly lower extension) output when both subs are working in together.
    Maximum Bitrate pcpete's Avatar
    Mar 2008
    Toronto Canada
    Is there a way to assign hotkeys or use girder to control levels in either audiomulch or console...
    I've got an m-audio fw 410 , and I've tried everything to send commands to it's mixer, with no avail....
    What I'm trying to do is be able to control the output levels to each channel via RR.
    I'm wondering if I switch to asio plugins and a console, will I be able to acomplish this...
    Thx, and sorry if this is sidetracking OP...
    Newbie Petegt's Avatar
    Jan 2010
    Norwich, United Kingdom
    I have a audiotrak maya 7 with 4 sets of stereo rca output and the hardest bit about it was setting up console.
    Feb 2007
    Limassol, Cyprus, Europe
    Quote Originally Posted by pcpete View Post
    Not sure about audiomulch or console, but Reaper definitely does it for me. I can control it through Road Runner this way, though i prefer to use my Space Navigator directly for this purpose
  1. Usb sound card recommendation
    By HuseyinOzsut in forum Car Audio
    Last Post: 10-11-2008, 07:49 AM
  2. Weird problem with USB sound card
    By ajamils in forum Road Runner
    Last Post: 04-23-2008, 10:02 AM
  3. FS:: [[ Auzentech HDA X-Plosion 7.1 DTS Connect Sound Card ]]
    By CoupeE46 in forum Classified Archive
    Last Post: 02-05-2007, 10:37 PM
  4. sound card help...
    By pimpmode in forum General Hardware Discussion
    Last Post: 06-02-2005, 12:32 AM
  5. Sound Blaster Live 24-bit 7.1 Audigy Sound Card
    By djXternal in forum General Hardware Discussion
    Last Post: 04-25-2005, 04:49 PM
