What proggys are you going to be using?
Currently, I'm looking at Allocator for XO, obviously, but I'm needing EQ, time alignment, phase & gain.
I realize that Allocator can do a lot of this, but I'm not sure I should use Allocator for all of it.
I'm still trying to figure out how I want to actually run everything. ie. exactly how I want to route everything and in what order.
Do I want to run an instance of Allocator for each channel? Do I want to run an instance of Allocator for left and an instance for right and go from there? (Allocator has the capability of 2 in and 8 out).
I then need an EQ per channel (would be ideal to be able to select the frequencies and the Q for each channel, not sure if there's a program out there that will allow for that).
Then I need Time Alignment per channel.
Then I need Phase per channel.
Then I need gain per channel.
While in an ideal world, I wouldn't need a lot of this, in a car, with a full dash and a lot of the constraints we have to deal with, it's inevitable.
So...Now that I have it for SURE working....many thanks for that....I'll be playing with this in the car, connected to the laptop, to see what I can come up with.
So what software are you using for all of this?
LinkBack URL
About LinkBacks
