Page 2 of 7 FirstFirst 1234567 LastLast
Results 11 to 20 of 69
Thread: SQ Sound Card
  1. #11
    Low Bitrate nalav's Avatar
    Apr 2009
    Louisiana
    Quote Originally Posted by efun View Post
    Any SQ difference between USB and PCI?
    It mostly depends on the hardware. Cheap USB devices won't have the hardware they need to produce high quality sound, but this is the same with PCI. Possibly the biggest difference is that it's able to be located outside the computer case, which potentially takes it away from electrical interference from the computer that could be affecting the sound. Though only audiophiles might notice a difference in the sound from this. The higher priced USB sound devices, just as the higher priced PCI sound cards, will be able to produce better sound quality. There is no inherent sound quality loss or gain simply by using USB, other than a few ms of latency that you won't even notice.
  2. #12
    Dec 2008
    Quote Originally Posted by _Dejan_ View Post
    Also please wait that first Me find PCI-E or PCI solution and then we will try find solution for you otherwise nobody will not receive answer an all will be mixed...
    The reason I post here is trying to find the solution about bitone, sorry if mixed up this post
  3. #13
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    I think for use with BitOne is best USB-SPDIF "adapter" Why?
    It doesn't need drivers(Problem with Hibernate/sleep solved).
    But Im not shure if I will continue use it...
    Regards, _Dejan_
  4. #14
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    Ok new Info.
    -Card must be on PCI slot
    -6 outputs, 1 mic input
    -ASIO support(Console and VST plugins for crossover, TA, EQ)
    So models for which I know:
    -Asus Xonar Essence ST + H6 DAC board (Can't find anywhere)
    -E-MU 1820 (Discontinued product and need aditional "Box")
    -Asus Xonar D2
    -Auzen X-FI™ Prelude 7.1
    -HT Omega Claro Plus+ (ASIO???)
    -CLARO halo XT (ASIO???)
  5. #15
    Jan 2008
    becaue console only supports one asio device for both input and output, you are going to end up either using asio4all, or will be looping the audio through the soundcard(looping it through multiple devices is the least efficient method)...
    i would have to say that any of those cards are going to work.
  6. #16
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    Quote Originally Posted by soundman98 View Post
    Ok if Im understand you. Console support only one device this mean If I disable onboard sound card and use another for example Claro Halo XT I can use original ASIO drivers because I will use one device?
    After talking with tech support Im 80% to take HT Omega Claro Halo XT sound card... It have swapable OPAMPS, 8xRCA outputs, optical IN and OUT, Headphone out, Line-in, mic, coaxial in&out, AUX-in, CD-in...
  7. #17
    Jul 2006
    Brisbane, Australia
    Just take the time to understand ASIO before you rush in like I did. I bought one of these a couple of weeks ago
    See: http://www.cakewalk.com/products/UAUM/UA1G.asp
    Despite lots of warnings in the manual about problems with the device not being found and possible problems of swapping it from one USB port to the other, it worked perfectly.
    Problem for me is that ASIO does not give you a master volume control so I could not get good functionality out of roadRunner and the Satnav volume punched me through the roof when the sound went from 4% to 100% volume unexpectedly...
    RR (and probably CF) needs hte master volume control for full functionality.
    There is a recent thread about my experiences, search for my posts.
    RodW
    2007 Toyota Hilux with a CarPC..
    Worklog: http://www.mp3car.com/vbulletin/work...ota-hilux.html
    OziExplorer GPS Embedded in RR: http://www.mp3car.com/vbulletin/sb-s...iexplorer.html
  8. #18
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    As I know with ASIO you can control Master Volume but you can't control Wave volume...
  9. #19
    Feb 2007
    Limassol, Cyprus, Europe
    This holds true in my case also
  10. #20
    Jul 2006
    Brisbane, Australia
    The above card has no Master volume control in the windows mixer. RR moves WAVE and Master together. Here was my post
    http://www.mp3car.com/vbulletin/road...d-card-rr.html
    RodW
  1. PCI Sound Card With RCA?
    By 356Speedster in forum General Hardware Discussion
    Last Post: 05-12-2009, 08:21 PM
  2. sound card recommendation
    By Stealth915 in forum Car Audio
    Last Post: 02-28-2008, 04:47 AM
  3. Old sound card....ARRRRRRRRGH!
    By jontz in forum General Hardware Discussion
    Last Post: 01-13-2008, 11:51 AM
  4. VIA EN1500G Faulty Sound Card?
    By Splash-X in forum General Hardware Discussion
    Last Post: 12-16-2007, 11:27 AM
  5. Any opinions on the Phillips Aurillium external sound card?
    By UMM in forum General Hardware Discussion
    Last Post: 02-27-2004, 04:39 PM
