Page 4 of 7 FirstFirst 1234567 LastLast
Results 31 to 40 of 69
Thread: SQ Sound Card
  1. #31
    Jan 2009
    how do you separate you chanel with windos direcsound... i have a 3way active system for my ront...and a sub.
    with asioforall it is asy..but i dont understand your method
  2. #32
    Jan 2009
    ok i got it...but soudman you seem o know how to remove vac?
    without asioorall..the sound is way more natural!...and i could locate each movement of the basist!
  3. #33
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    Quote Originally Posted by kross View Post
    I, too, switched to Audio Mulch, and am happy to be rid of asio4all. I still use VAC for input, but I just use the regular Windows DirectSound driver for output. My audio is happier.
    Hi,
    If I remember AudioMulch have option for MME, DirectSound and ASIO output. If Im right MME allow you only Stereo output, DirectSound and ASIO allow you multichannel outputs. I with AISO4ALL get some strange random pooping/crackling(1-2x in 5 min) with all buffers to full, with native ASIO I get a lot of less this pooping/crackling(1-2x in 30-60min). When Im test DirectSound(or MME I don't remember which allow multichannel) Im not get any pooping, but sound has been a lot of different than with ASIO, it looks like Im lose cca. 20-50% volume gain and music has been less detailed. But I will try it again on my notebook because maybe has been problem beta drivers for my sound card... If I play sound from WMP to direct speakers I get normal sound...
  4. #34
    Jun 2008
    Seattle, WA
    Are you using Virtual Audio Cable with Audio Mulch? If so, maybe you have "volume control" enabled in the VAC control panel, causing audio output through it to be too quiet.
  5. #35
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    Yes Im using VAC with Volume control enabled.
    In ASIO4ALL I use VAC with same control panel settings as in DirectSound so I don't think that Volume in VAC is problem. Im set all Volumes to 100%... But I will try disable volume control in VAC when I will again try DirectSound if maybe is some internal problem in VAC driver...
    Currently I using:
    ASIO4ALL(Buffers to full)
    VAC 4.09
    AudioMulch 2.0.2
    Centrafuse
    VST Plugins:
    5x Electri-q(2x for TW, 2x for MID and 1x for SUB)
    1x Voxengo Sound Delay
    But Im not very happy with result because I get random pooping...
  6. #36
    Jun 2008
    Seattle, WA
    I went from using the free VST Host program with ASIO4ALL, to using AudioMulch with DirectSound output, and the audio volume is the same as far as I can tell.
    It could be you haven't raised the volume on the correct mixer device. Double-click the speaker icon, and select Properties from the menu, and select each mixer device in turn (one for VAC, one for your sound card), and make sure the volume is turned up. This is assuming Windows XP, as that's what I have. It may be different on Vista or W7.
  7. #37
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    Im 99% shure that all volumes has been on 100% and balance for each output on 0 in cmedia control panel and windows mixer. Problem is not only volume. Sound has not be as must it has been like it cut some MID frequency out, some SUB frequency and tw frequency, but I can't tell for shure until I re-test it again and see what will happen now. Maybe is something with Electri-Q that do not work with directsound... Because If I remember if Im direct link input to output has been better... I will see in next days when I will test again and ty LS_Filter too...
  8. #38
    Jan 2009
    what is you power suply and your soudn card?
  9. #39
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    Now Im back from garage. Im spend 3h with trying to get work DirectSound.
    In AudioMulch Im select DirectSound
    Then Im for Input device select Line 1(Virtual Audio Cable)
    Set buffer to 8192
    For Output Im select Speakers (Claro Halo)
    Set buffer to 8192
    In Audio Input Im assign to SoundIn: Line1(Virtual Audio Cable) CH1&CH2
    In Audio Output Im assign to SoundOut: Speakers (Claro Halo) CH1&CH2 (TW)
    AuxOut1: Speakers (Claro Halo) CH3&CH4 (SUB)
    AuxOut2: Speakers (Claro Halo) CH5&CH6
    AuxOut3: Speakers (Claro Halo) CH7&CH8 (MID)
    No mather to which Output I connect signal allways play only from tweeters :S So from other speakers I can't get sound.
    Console:
    If I select DirectSound I can from combobox select only modex which are 2 channel for example something like this:
    44100Hz/24Bit/1CH
    44100Hz/24Bit/2CH
    48000Hz/24Bit/1CH
    48000Hz/24Bit/2CH
    96000Hz/24Bit/1CH
    96000Hz/24Bit/2CH
    I think I will change soundcard to some other PCI card which have Internal routing and Windows 7 support but first I must find it...
    Quote Originally Posted by summer69guy View Post
    Power supply is M4-ATX which work good. Soundcard is Claro Halo XT
  10. #40
    Jan 2009
    have you tried with a home psu directly on the motherboard with a pair of headphone?
  1. PCI Sound Card With RCA?
    By 356Speedster in forum General Hardware Discussion
    Last Post: 05-12-2009, 08:21 PM
  2. sound card recommendation
    By Stealth915 in forum Car Audio
    Last Post: 02-28-2008, 04:47 AM
  3. Old sound card....ARRRRRRRRGH!
    By jontz in forum General Hardware Discussion
    Last Post: 01-13-2008, 11:51 AM
  4. VIA EN1500G Faulty Sound Card?
    By Splash-X in forum General Hardware Discussion
    Last Post: 12-16-2007, 11:27 AM
  5. Any opinions on the Phillips Aurillium external sound card?
    By UMM in forum General Hardware Discussion
    Last Post: 02-27-2004, 04:39 PM
