double check the differences between answers
ok if you want 2-dvc 4ohm subs at two ohms on the amp...then series the voice coils then parallel them subs from the box or you will drop the amp amp to 1 ohm if you parallel both the voice coils and subs to the bridged/mono amp...just trying to make sure you dont fry the a/b circuitry in a 2ch bridged amp or even a 2ohm stable mono amp... if you want 1 ohm then get a mosfet class d mono that is capable... and for a 2 ohm 2 ch is the set up i explained and if its not a mosfet amp then dont bridge or the amp WILL NOT hold the draw from the subs and for a mosfet class d mono then you shouldnt have any problem if you series voice coils within the box then you can choose a 1ohm or 2 ohm load just by either series the terminals on the box for a 2 ohm or parallel them for a 1 ohm... been doing this for 9 yrs and ive seen alot of common mistakes made by a full parallel on a non mosfet or class d and when the amp surges right before it dies then kiss at least one sub goodbye... just be very attentive to how you wire them up for your sake and your wallets...oh and for the cap if you run 1000w just to be sure you dont get that "bath tub" effect lol... just refer to this and it will help without doing the big three..
500w=1farad
1000w=2farad
thats basic specs so run a bigger cap with a 16v continuous and 20v surge and you wont get that effect so i would run a 3farad myself
