Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Subwoofer Ohm wiring
    Jan 2010
    Alright, So im wanting to wire up 2 DVC 4 ohm subs. I was wondering, is it possible to wire them to run a 2 ohm load? i know i could run 1ohm, but the amp im looking at pushes 1000RMS at 2 ohms and these subs are rated 1000rms each. Thanks in advance.
    Variable Bitrate vincenttor's Avatar
    Nov 2008
    maybe this could help ?
    check for full info here
    http://www.12vhifi.nl/subframe.html
    first is how much subs
    second is dvc ?ohm
    third is mono amp or bridged
    goodluck
    Jan 2008
    Quote Originally Posted by vincenttor View Post
    second is dvc ?ohm
    goodluck
    i belive that using 4 ohm dvc's in that arrangement would give you a 4 ohm load at the amp. (math: wiring the subs as series 8 ohm, and then parralling them to half would be 4 ohm...)
    to get a 2 ohm load, you would need 2-2ohm, dvc subs.
    it is just not possible with 4 ohm dvc subs.
    though, i prefer to not run anything lower than 4 ohms-- it is just too close to a dead short for me to feel comfortable with..
    Maximum Bitrate bratnetwork's Avatar
    Oct 2007
    Haledon, NJ
    Jan 2008
    Dartmouth, MA
    In a series circuit, you add the resistance of each thing. If you were to wire these subs in series, it would be an 8 ohm load.
    In a parallel circuit, you add the inverse of each thing and then take the inverse of that answer. Ex. 1/x = 1/a + 1/b + 1/c and solve for x.
    In this case, a parallel circuit is your solution because
    1/x = 1/4 + 1/4
    1/x = 1/2
    x=2
    Short answer: wiring them in parallel will give you a 2 ohm load.
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
    Jan 2010
    ok, thanks for the help guys, So i would be able to run 2 DVC 4ohm subs at 2ohm load if there wired in parallel? PaulF says yes but soundman98 says no? Also, lets say my amp pushes 1000RMS @ 1ohm as well as 1000RMS @ 4ohm, What is the difference if i wire and run them at 1000RMS @ 1ohm rather then 1000RMS @ 4ohm? Is 4ohm better then 1 or 2? I just really want to know my options so i dont go buy the wrong amp and subs since these subs retail 450+tax a piece
    Nov 2008
    you can see on the website exactly how it should be wired that i gave u
    just set how many what amp etc and ur done
    see the pic by the story and its done in a minute
    Jan 2010
    Ok, Ive decided to get the 4ohm subs. Im going to wire them to run 1ohm load. Could anyone recommend a good amp that puts out 1000RMS @ 1ohm? Im having trouble finding a decent amp. Im looking to spend under $300 and would like to stay with the big brands like alpine, mtx, pioneer, kenwood etc. Thanks
    Jan 2008
    Quote Originally Posted by PaulF View Post
    1/x = 1/4 + 1/4
    1/x = 1/2
    x=2
    each individual sub can be setup as a 2 ohm load like you speced. using all 4, 4 ohm voice coils, there is no way to connect the 4 as a 2 ohm load...
    there isn't really a cheap 1 ohm stable sub amp-- that is this close to a dead short, and to get a amp that reliably puts out in that condition, it is not cheap...
    Jan 2010
    So a 1ohm load is not as safe to run? I guess ill find a amp that puts out 1000rms @ 4ohm, or get the dvc 2ohm versions of the subs because the amp i was looking at puts out 1000rms @ 2ohm. I heard the 2ohm DVC subs in general are not as popular as the 4ohm ones?
  1. embarrassed to ask: subwoofer wiring?
    By telekineticfool in forum Car Audio
    Last Post: 09-14-2009, 04:32 PM
  2. need help wiring a 1 ohm amp to 3 two ohm subs
    By jjpburton in forum Car Audio
    Last Post: 10-29-2008, 11:13 AM
  3. dual vioce coil sub/amp wiring
    By hotponyshoes in forum Car Audio
    Last Post: 12-24-2007, 01:20 AM
  4. FS: Diamond Audio D6 10" Dual 4 Ohm Subwoofer
    By Chromelore in forum Classified Archive
    Last Post: 12-08-2006, 09:22 PM
