Results 1 to 10 of 16
Thread: Master Volume Control?
    May 2010
    i was looking into the KXproject as i have a soundblaster eligable for use, no from the hours of reading around FAQ's and what not i havent got a clear understanding on how the master control volume works, essentually i want my carpc to boot up with everything started. and the volume control in RR (systems master volume) to control the level of the KX audio programs volumes, i plan on using it for my crossovers, i just want piece of mind that the master volume control can control all the volumes.
    also i was wondering if all sounds on the system go through the audio processing? from what im seeing you have to config each program to use a specufic sound device for its sound to be processed?(is this just for aiso)
    my understanding is the KXproject the sound card does all the work, so does that mean all sounds go through the crossovers, and the systems master volume works nice and smooth?
    Jan 2008
    its been a while since i used my soundblaster card and kxproject drivers, but from what i remember, your on the right path-- the master volume can still be controlled by the computer(though i want to say that you need to add a master volume plugin-- i remember downloading one at some point), all the processing is done on the card, where you can digitally rewire it to do whatever you want..
    if you want to use asio, every audio device that you want to use it will need a asio driver
    May 2010
    thanks man yeah i want the computer/front end to control my volume 100% and the KX seems to be good for what i want, being and EQ and crossover
    EDIT NEW Q: i want to retain a mic input (voice commands and BT phone) and an AUX in for what ever, can u still have input ch's for instance a mini-mini cable from mp3 player to line in, and still play the "line in src" out the crossed over ch's
    Jan 2008
    like i said, it has been forever(last i played with kxdrivers was when i first built my car computer-- a year and a half ago..), but i want to say that it does still allow aux inputs.
    that was a partial requirement that i thought i had gotten working on my setup, though i don't remember ever testing it, so it might not have worked after all...(long story short, the card worked great, but the pci flex adapter i used didn't like to let the computer post, and so i had to put the card off to the side and use a usb sound card.)
    May 2010
    Im throwing up using and Audio control 3xs (for my active crossover need), or the kxproject, i just need to make sure i can acompish what i need with KXdrivers, is there any KXdrivers users that post in this forum?
    Oct 2004
    Israel
    Yes , Yes And Yes
    You can absolutly control the master volume with kx ( even if you use ASIO )
    And you can get the line-in through all of the filters
    Just try it and start messing with the KX DSP and you'll see everything
    HeadUnit : Car-Pc | Processor : JBL MS-8 | Front Stage : Woofer - Mpyre 65M , Mid - Dayton RS100-4 , Tweeter - Tang-Band Ceramic 25-1719S | Subwoofer : Hertz HX250D | Amps : A/D/S PQ10 , Hifonics Olympus XI , SPL AB03445 | Wiring : Sommer , Neutrik
    Feb 2010
    where does one get a KX soundcard here in the US?
    Oct 2004
    Israel
    Ebay?
    Search for Audigy 2 ZS SB0350
    May 2010
    Quote Originally Posted by Madboy View Post
    Yes , Yes And Yes
    so you have personally used roadrunner or centrafuse to control the systems volume with KXdrivers? so no need to leave front end for volume control?
    Jan 2008
    Quote Originally Posted by Darkhorse972 View Post
    careful searches.
    most of the supported cards have been discontinued-- i've seen them occasionally being sold as refurbished, but otherwise, pure luck... if your interested in calling around, the fry's near chicago had a bunch of refurbished ones in the last year or so, so it might be worth checking out(they were refurbished, so you might need to call to actually locate them..)
    the entire project is kind of old--most of the links either don't work, or the last revision was a couple years ago, so running vista/windows 7 with one of these cards and drivers, has got to be a experience equal to electrocution...(i think it might need to be run in xp compatibility mode)
  1. OEM Radio Integration - Volume Control
    By canadiandream in forum Input Devices
    Last Post: 08-24-2009, 10:40 PM
  2. Volume control and ASIO sound card in RR
    By rodweb in forum Road Runner
    Last Post: 08-07-2009, 03:43 PM
  3. volume control questions
    By dmx21 in forum General Hardware Discussion
    Last Post: 06-04-2009, 04:42 PM
  4. Volume Control on Vista x64 Problem
    By potpeye in forum Road Runner
    Last Post: 05-10-2009, 03:32 AM
  5. Replies: 12
    Last Post: 07-31-2007, 02:05 PM
