Results 1 to 8 of 8
Thread: Time Alignment Plugin
    Variable Bitrate heezer7's Avatar
    May 2004
    IL, USA
    Anyone have a free one they would suggest? I think I have just about everything set but that.
    Jan 2008
    http://www.kvraudio.com/get.php?mode...ts&st=adv&soft[]=e&type[]=12&f[]=vst&win=1&free=1&sf=0&receptor=&de=0&sort=2&rpp=1 00
    the one that works best in my test is one that is simply called "variable delay" though the author never put any details in the properties, so i can't locate it again..
    Jun 2009
    I use Gdelay http://www.kvraudio.com/get/2186.html
    Worked well for me so far although I wish it would allow for more precise adjustments (.01 ms increments rather than just .1 ms)
    May 2004
    IL, USA
    Thanks. I figured if anyone had one to suggest it was a better start than randomly picking from the huge list. Will try that one out.
    Jan 2008
    i have attached the variable delay plugin here. just change the ending from .txt. to .dll
    mods: i cannot locate any info on the creator of this plugin, and it was a free download, so i don't believe this violates any rules, but if it does, feel free to remove attachment..
    Attached Files Attached Files
    May 2004
    IL, USA
    Awesome. Between the 2 I should be set. Just need my midbass speakers to ship now! Thanks all.
    Nov 2010
    Quote Originally Posted by soundman98 View Post
    from what i could tell, the granularity is only 1ms for that vst. that equates to roughly 1ft. i didn't see a way to enter a number lower than 1ms.
    i have found that voxengo's free sound delay has much finer control and also has level adjustments, killing two issues with one vst.
    Nov 2010
    Another option is SDelay, built into audiomulch. I haven't used it, but looks like you can enter exact numbers less than 1ms.
  1. MP3Art Plugin - UPDATED 11-17-2010
    By mitchjs in forum RR Released Plugins
    Last Post: 12-17-2010, 11:41 PM
  2. Virtual Earth cache builder? Or even gps simulator to make it cache?
    By thepunkerguy in forum DigitalMods (Scripts / API)
    Last Post: 08-28-2008, 09:58 PM
  3. Replies: 119
    Last Post: 12-25-2007, 03:20 PM
  4. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 09:26 PM
  5. 1.0.4.7 bug
    By debugger in forum StreetDeck
    Last Post: 07-01-2006, 04:01 AM
