Page 19 of 46 FirstFirst ... 91011121314151617181920212223242526272829 ... LastLast
Results 181 to 190 of 458
Thread: Software options for Tuning
  1. #181
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    Quote Originally Posted by turbocad6 View Post
    my first thoughts along these lines were that it will be processor intensive... my second thoughts were to use a dedicated machine for this, & then another as the actual carpc...
    I mean the alpine is a dedicated box, so this could be too... a kvm could keep this managable through one screen... I don't know if I'm the only one who would consider multiple machines though... I have 2 motherboards going in my minivan right now, one for front & one for rear... adding a 3rd wouldn't be that intense for me....
    I'd be afraid trying to run everything on one machine will cause issues, maybe a really fast dual core with a system that can take advantage of this, but I would rather do independant pentium m machines.....
    so how crazy is running a dedicated machine for audio processing? would anyone else consider this?... imagine if it could run on linux... it could be kinda like the alpine in the end, BUT with everything we'd want... best audio quality with pc interface.... is this a consideration? I don't know enough about linux to do this, I guess a stripped down xp machine could do this well too.... maybe an xp embedded solution.....
    Ya I was begining to think the same thing. It would be a total geek cool factor. I know for competing it would help me out because there is usally points for having an external processor. Having it all built into a headunit/computer just doesn't seem to count...BASTARDS! I look at it as an expense and space factor though. I liek that everythring I have takes up as little as space as possible and is hidden with still plenty of trunk room. Hmmm...
  2. #182
    _
    Mar 2004
    Little Elm, Texas
    I'm not willing to consider multiple machines at this point. I simply don't have room for it.
    Since I'm not concerned with ultimate sound quality while watching DVDs (which I don't do) and since I'm not concerned with audio in 5.1, I'm feeling that it won't be nearly as intense as the guys over on DIY are experiencing.
    I'm also looking at running a micro-atx board with a Pentium D 3.4 GHz and 2 gigs of ram to do this.
    Sure, powering it will be difficult, but there are ways around that now.
    regarding linux - there were some guys int hat DIY thread that were talking about it, not sure if anyone followed through on it though.
    Jan Bennett
  3. #183
    Oct 2004
    NY
    I guess this is true too... with a simple stereo setup there will be only 5-6 x-over points... I'm assuming the xovers will be the most intense part of processing...
  4. #184
    _
    Mar 2004
    Little Elm, Texas
    all, I've posted over there at DIY, but it seems my post has fallen on deaf ears since it's for a car and not home audio.
    If some of y'all could possibly post over there and encourage a bit of conversation and show that there is a good deal of interest in this in a car, perhaps we could get a bit of talk rather than a bunch of folks who look down their noses at car audio....
    Jan Bennett
  5. #185
    Sep 2006
    On my way over....
  6. #186
    Sep 2006
    Hey RED-
    I posted over there so we will see. Also that wave program they are using looks like an EQ based program. You can pretty much use an EQ as a filter. FIR filters are harder to design than IIR filters- (a digital based analog filter/crososver) because there are not easy models to base them off of. It's probably easier to design an EQ based on FIR filtering. I wish I could explain it better but I am extremely rusty on my knowledge of it. I was doing a little research to jog my memory but I never seem to have time to get it done.
  7. #187
    Variable Bitrate FyreDaug's Avatar
    Jan 2005
    Saskatoon, SK
    Heres something that I dont know if it has been mentioned or not. Heres my situation:
    I have 2x200gb hdd full of music, .ogg, .flac, .mp3, .wma. The oggs and wma are few and far between but between the mp3 and flac I have some problems.
    The 31band EQ in winamp will ONLY have an effect on lossless music, IE, my flacs, I can also not use the winamp bass/treble controls (which I like to keep both at -4% just to take a little edge off, but sometimes I turn it down to -25% on the bass for some songs, as its just easier to fiddle with instead of opening the eq.
    The mp3 songs work fine with the winamp controls, but have 0 effect with the eq. I tested this by obviously using a flac and mp3 of the same song (which Roxette- The Look happened to be the test subject) and clearly 31bandeq=flac files
    winamp bass/treble = mp3 files
    I used to use this 4front EQ. Its 10band, but im going to test it out again with mp3 vs flac and see if it works for both. If it does, it looks like I have to downgrade my EQ.
  8. #188
    Sep 2006
    Quote Originally Posted by FyreDaug View Post
    Hmmm.. I used it sucessfully on mp3 files and cd audio files. I don't have any FLAC files. I'm using Winamp 5.24 and the vst plugin configured to use the free vst EQ from the first page of this post.
    EDIT: I noticed every now and then it freezes on some mp3s when using ASIO output plugin only.
  9. #189
    Jan 2005
    Saskatoon, SK
    "freezes" as in winamp locks up? I have that problem sometimes if thats what you are talking about. its kinda rare.
    But it has NO effect on any of my mp3's, why would that be?
  10. #190
    Sep 2006
    Yes, Winamp locks up. Probably just bad MP3's. I don't really know though.
    I am not sure about your strange problem. Just remember though that a 31 band EQ makes small adjustments versus a 10 band. If you adjust a bunch of bands that are close together then you should see a more drastic change. If you notice a difference on the FLAC files though then you should notice a difference on your MP3's on any changes you make. What is your software/hardware setup exactly? I need more information and I will try to duplicate your problem.
  1. AutoTap used to develop custom software!
    By Dodger1417 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 09-25-2006, 11:51 AM
  2. comparison of GPS Software
    By gunsandrosses in forum Newbie
    Last Post: 06-28-2006, 10:56 PM
  3. CarPal Bluetooth Module & Digimoto Software....A Very Good Combo..
    By jmciver in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 06-16-2006, 05:08 PM
  4. Replies: 2
    Last Post: 11-15-2005, 02:38 PM
  5. CoPilot Software or USB GPS Receiver package
    By Zip-Lock in forum Classified Archive
    Last Post: 05-13-2004, 08:30 AM
