durwood, can you explain what these plugins are for exactly?
is the first one just a 10band EQ?
Adding links for the UFX plugins and Profx plugins
UFX plugins for the kxdrivers
http://www.driverheaven.net/showthre...ighlight=profx
Profx plugins for the kxdrivers
Now time to go play...![]()
System always under construction
Jan Bennett
I am not for sure YET. I won't get a chance to try them out until Thursday hopefully. From what I was reading, I thought there were crossver plugins inside the UFX package. I might be wrong. I really can't say. I think there is a parameteric EQ in there as well as the pointless 10 band.
The thread is extremely long 15 pages worth and not really any mention of featuresMore details to come...
How can you use the
" 31-band Graphic EQ VST 01 - free "
What does the dll go with?
if I'm not mistaken, it will need to be used in a player that can take VST plugins.
Jan Bennett
that's what i understood also, from reading the functioning and requirements, yes.
Xenia & Isabelle, totally in love!
'T SQiekenkot: VOLVO 740GL 2.3
CarPC: none at the moment
CLARION HX-D2
CLARION APA4300HX => Fountek NeoCd1.0 + TB W4-1337SD
CLARION APA4300HX => CSS Trio8
CLARION APA2100 => Dayton IB385-8
I suppose winamp isnt a vst plugin player![]()
Try this...
http://www.winamp.com/plugins/details.php?id=146317
EDIT: This VST Winamp Bridge Allows you to load a single vst plugin such as the 31 band EQ on the first page of this post. I tested it and it worked. If you read through the reviews someone mentions some vst stacker plugings that you could use to laod more than one vst plugin for winamp.
holy hell, im gonna check that out
I had a close look at the KX driver DSP programming tutorial. I'll have to do more study, but it appears that I can program 2nd / 4th order Crossover, as well as 31 band EQ (I don't see wny you can't have n-band EQ).
What I am particularly interested in, is a Parametric EQ. In home audio and recording, the parametric EQ is usually regarded as more useful tool than fixed frequency EQ. By the time you punch in 5-6 PEQ's, you can have far more control than a 31 band EQ. But I am not very sure how I'd program PEQ in custom KX plug in.
