Page 5 of 46 FirstFirst 123456789101112131415 ... LastLast
Results 41 to 50 of 458
Thread: Software options for Tuning
  1. #41
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    Quote Originally Posted by jasonsjwou View Post
    I had a close look at the KX driver DSP programming tutorial. I'll have to do more study, but it appears that I can program 2nd / 4th order Crossover, as well as 31 band EQ (I don't see wny you can't have n-band EQ).
    What I am particularly interested in, is a Parametric EQ. In home audio and recording, the parametric EQ is usually regarded as more useful tool than fixed frequency EQ. By the time you punch in 5-6 PEQ's, you can have far more control than a 31 band EQ. But I am not very sure how I'd program PEQ in custom KX plug in.
    The 2nd and 4th order crossovers AND parametric EQ should be in the UFX package. There was a thread in driverhaven about a 31 band EQ for car use, but a few agreed that there might not be enough resources to process that many bands within the sound card alone. From what I remember from my DSP programming, even a simple EQ requires many resources from the DSP chip used.
  2. #42
    _
    Mar 2004
    Little Elm, Texas
    that would be why most of the programs require some pretty hefty processors.
    do you happen to have that link to the driver haven discussion?
    Jan Bennett
  3. #43
    Sep 2006
    Quote Originally Posted by RedGTiVR6 View Post
    Here it is...see post 12. The guy who programmed the UFX plugins is in that discussion as well.
    http://www.driverheaven.net/showthread.php?t=120473
    It sounded like you could string the 5 band parametric EQ together. (Or you could use the 31 band VST pluging with Winamp.) Its not one complete software soultion but at least I am rethinking my use of the Alpine processor again. Dammit!
  4. #44
    Variable Bitrate FyreDaug's Avatar
    Jan 2005
    Saskatoon, SK
    Wow damn durwood, I give you the noob award of the year. Since you got here youre full of information, im lovin it. That VST plugin and that 31 band EQ just made my day, its so much better than the 4front eq which was like 10band 1 octave. This winamp eq will do all my equalizing. I wont use any artificial boosts or anything. Just to get it as flat as possible (link to tune) as I know I have some overlapping frequencies with my component sets... I havent even heard it yet and I know im gonna need some tuning. But once is all said and done its gonna be awesome. Plus with that line driver you sold me, I should have excellent efficiency
  5. #45
    Oct 2004
    NY
    , guess all n00bs aren't bad n00bs jk nice to have your input for sure
  6. #46
    Sep 2006
    Thanks and cheers to everyone here. I just wanted to help others as much as I can. I remember when I got into car audio 10 years ago and carputers 3 years ago. I struggled through both eras trying to gather as much info by learning, researching, experimenting, and asking questions. ..and just when I think I got it all figured out a whole set of new ideas comes around (thanks mostly to RED and scott_fx ). I just want to pass it along because there are so many out there who don't share...but hey...I am a car audio/computer/electronics junkie. I need a support group.
  7. #47
    _
    Mar 2004
    Little Elm, Texas
    heh - THIS is one hell of a support group.
    Sounds like we're one step closer to an all in one solution! And kudos if we can use winamp for it all!
    Jan Bennett
  8. #48
    Oct 2004
    NY
    my biggest single concern with a total setup like this is going to be processor usage... how much will it take to run this behind the scenes, & how heavy of a performance hit can we expect on a carpc.... that's got to be the main variable that will make this either very practical or very impractical..., anyone have any idea on this??
  9. #49
    Low Bitrate jasonsjwou's Avatar
    Sep 2006
    KOREA,USA,AUSTRALIA
    durwood, I really appreciate your input, as well as Red and scott_fx and everyone in this forum. People with a "real" knowledge under their belt.
    I know that a Parametric EQ is more computationally efficient than Graphical EQ. See the latest apple IPOD's patent, which basically converts 10-band graphical EQ into single Parametric EQ - is 10 times "lighter" on processing power.
    http://www.macsimumnews.com/index.ph..._ipod_and_more
    This is why you see more of Parametric EQ's on digital mixers (such as Yamaha Digital mixers). In your stand along GEQ, it is composed of passive RCL or active OpAmps for each freq band, so # of band does not really matter. But that is why they are not very precise (or the precise GEQ's are very, very expensive).
    But in all-digital domain, the PEQ is better. I am sure that somebody somewhere has worked out the math of converting a Graphical EQ curve into n # of PEQ's with appropriate parameters, and wrote some codes for it. Personally, I think 4 PEQ's can create whatever the 31 band GEQ can give you (in Practical Audio Application), only 10 times faster in processing speed.
    I have a DEQ2496 Behringer processor/GEQ/PEQ with RTA that I use in my Recording Studio. It has a Microphone input. It generates Pink/White noise, measure the overall frequency response at the position of the mic, draws the curve, inverts it, and makes a "suggestion" of GEQ that makes the overall frequency response flat. I'll have to go look at the manual to see if it can also give a "suggestion" on PEQ settings, but I'm sure this is possible with a software and a soundcard. May be this one can do it?
    http://www.trueaudio.com/
    Too bad their free version can only do 1 oct. We need 1/3 octave to be at least useful.
    Whoa. Aren't we havin' fun yet?
  10. #50
    _
    Mar 2004
    Little Elm, Texas
    There's no doubt that something along these lines will be very processor intensive.
    however, in my eyes, at this stage of the game, if you want to be able to do this, it's something you'll have to accept.
    The way I see it, until the need is made known, there's no reason to code it any differently. I'm not sure if there would be a way to decrease the processor load on something like this...but then again, I'm not a programmer by any stretch of the imagination.
    Jan Bennett
  1. AutoTap used to develop custom software!
    By Dodger1417 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 09-25-2006, 11:51 AM
  2. comparison of GPS Software
    By gunsandrosses in forum Newbie
    Last Post: 06-28-2006, 10:56 PM
  3. CarPal Bluetooth Module & Digimoto Software....A Very Good Combo..
    By jmciver in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 06-16-2006, 05:08 PM
  4. Replies: 2
    Last Post: 11-15-2005, 02:38 PM
  5. CoPilot Software or USB GPS Receiver package
    By Zip-Lock in forum Classified Archive
    Last Post: 05-13-2004, 08:30 AM
