Results 1 to 10 of 13
Thread: Digital Audio Correction / Digital Room Correction DRC
    Dec 2006
    Fairfax, Va
    Thought you might find this to be interesting:
    This is how I did it:
    http://members.cox.net/mikemcd/S2000...rrection.shtml
    _
    Mar 2004
    Little Elm, Texas
    not sure about this.....*scratches head*
    Jan Bennett
    Mar 2002
    Grassy Butte ND
    So am I correct in assuming the music is processed and then stored for playback to match the output of the car then? So unless the music is previously processed it won't sound correct?
    Dec 2006
    Fairfax, Va
    Yes, I preprocess the music and store it on an Ipod to play in the car. You can also play unprocessed music using a computer, through a player with a convolver (e.g. Foobar, WMP, etc).
    Standard CDs also work fine - a little better than stock due to the improved crossovers.
    Jan 2007
    great info here!! what software are you using to generate the sine sweep, capture the impulse response and make all those nice graphs with?
    i am in the finishing stages of part1 of my install - second amp isn't in yet, but i can capture the impulse response of each individual driver. when finished, i will have a 3-way active frontstage plus sub
    i tried using Room eq wizard, but my graphs didn't come out nearly as nice as yours, so i have been looking for an alternative software program
    i am using an ECM8000 with a calibration file to capture the sine sweep through an m-audio mobilepre
    i plan on using offline processed music as well, through an alpine cda-9830, until i can afford a carpc and auzentech xmeridian soundcard
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    Sorry we didn't respond to this directly, I remember reading your page from a link someone posted in the DIYaudio forums on the howtoXO thread. It's just not a solution thread works for us. Similar to Accurate by Uli. Here's the problem:
    1) I have a huge music collection as well as many of us do. To convert the music and save it to disk is ALOT of work. And this doesn't work at SQ competions. You are required to use their CD. WHat happens if you change something? Then you have to reconvert ALL the music again? Yikes!
    2) BruteFIR/Convolver is for coders and programmers. I would rather have something I can change on the fly in real time. How am I supposed to tune with bruteFIR or convolver in the car? The car is not anything like home audio. It's a completey different animal. MOST Automatic RTA's don't even work in a car if you ask people who know about what it takes to get Great sound in car. You can use it to help you tune, but I would never rely on it to make corrections for me.
    If you have had good luck with DRC anc convolver and bruteFIR then cool. We were looking for something that mimics current car aduio gear but takes it a step beyond for more flexibility and ease of use. Ease of use is a major key factor. Like I said again, if this method worked well for you cool, but I think most of are looking for something else. The ASIO and VST plugins are very powerful IMO.
    Cheers
    Dec 2006
    Fairfax, Va
    jmelan:
    The DRC package has a small program that will generate the log-swept sine wave. You can use Adobe Audition to both play the sine wave through your audio system and record the output. However, I put the sine wave in my Ipod so any coloration it generates is also corrected. (Ironically, the original Shuffle has the flattest frequency response: http://home.comcast.net./~machrone/p...playertest.htm ,and I have verified the phase response to be flat.) You can download a fully functional 30-day trial version of CoolEdit, which was the predecessor to Audition. I use Matlab to process and plot the filter and impulse response files. Audition and Foobar have convolvers, in addition to the WMP convolver.
    Jan 2007
    thanks. i think i found it. that manual is pretty intimidating!
    there seems to be a script in the DRC manual also to process the impulse response through octave (matlab?) and auto generate all kinds of graphs
    i am going to try a run through this today and see what kind of results i get. i am not the best with command line interfaces.
    did you alter your DRC config file to optimize for car audio, or was one of the preset ones ok (minimal, normal, erb...)?
    Dec 2006
    Fairfax, Va
    jmelan: Yes, this will most likely take you a lot of time. Here is another good guide: http://www.mooneyass.com/DRC/DRCGuidev1.0.pdf . The DRC scripts are designed to work with Octave, but Ocatve is not real Windows-friendly. I got the best results by starting with the config file that Denis uses for his system - in my case, it does a better job of correcting phase.
    Jan 2007
    Hi,
    How did you change the volume level of your FIR filter?
    "Volume Correction
    Because the driver is significantly off-axis to the left speakers and the driver's left leg blocks the output of the left lower speaker, the left channel output was increased by 3db in the FIR filter to match the level of the signal arriving from the right speakers. This helps to center the sound stage and improves imaging."
    I am measuring a 2.25 dB difference on average in my left versus right channel from my listening postion and can't figure out how to correct for this.
    Can I do this in Audition?
  1. Digital Vs Analog and Soundcards/Amps
    By kickstep in forum Car Audio
    Last Post: 11-22-2006, 04:37 PM
  2. Digital Audio drop out???
    By Will Albers in forum Car Audio
    Last Post: 04-25-2006, 04:41 PM
  3. audio specs help
    By scott_fx in forum Car Audio
    Last Post: 03-25-2006, 05:43 PM
  4. some audio questions for my setup
    By PatrickB in forum General MP3Car Discussion
    Last Post: 05-11-2005, 08:37 AM
  5. Seperate VGA and S-Video with Audio
    By Fox_Mulder in forum General Hardware Discussion
    Last Post: 07-01-2004, 02:44 AM
