Page 25 of 38 FirstFirst ... 151617181920212223242526272829303132333435 ... LastLast
Results 241 to 250 of 377
Thread: audio over USB v. optical
  1. #241
    Maximum Bitrate pRoFiT's Avatar
    Apr 2005
    Fresno, CA
    FYI: I didn't read all 16 pages so maybe you know already. USB 2.0 has a shared bandwidth of 480Mbps Unless of course the motherboard has more then one USB controller. I only mention this because I thought I read something about you wanted to do dual usb dacs. Which would have to share the same 480Mbps anyways.
    Vista........I'm waiting for SP1 and 6 months, which ever is longer. And it takes like 800+megs of ram to run with no programs! I think Vista is too much of a power hog to try and run in a car. Maybe for a Home theater system or DJ system. Well thats my 2 cents.
    Depending on final cost i may want a non vista one . added to watched list
    Um, I guess this is where you put something witty.WITTY
    My Web site, in the design stage. http://home.comcast.net/~cstrachn
    Modified RRSkinEditor http://www.mp3car.com/vbulletin/rr-skins/65723-rrskineditor-bugs-fixes-comments-current-progress-outdated.html
  2. #242
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    I am pretty sure bit perfect is out. Since the audio will be processed by the CPU anyway and ASIO is needed, it won't work from my understanding. Instead, all we need to really focus on is Jitter.
  3. #243
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by JasonWW View Post
    I'm all for you guys making a device to extract the highest quality you can from the PC and all so I will be following this thread. My biggest hurdle right now is that I assume we are talking about using Bit Perfect to this new device and that means no volume control in Windows nor being able to play DVD's or having any other computer sounds. This is why I haven't tried Bit Perfect. Are you guys also going to sacrifice those other sounds for the music?
    If we do all audio processing on the computer, it won't be bit perfect any more. regardig Durwood's comments.
    Jan Bennett
  4. #244
    Oct 2005
    Hou. TX
    Quote Originally Posted by pRoFiT View Post
    I think I would be fine with a 3000+ AMD, but I really didn't think of the guys with the Epia and slow CPU's. At the same time, with this new mutiple DAC device were discussing, would it be able to run on a low speed processor like most folks have or would they need to upgrade to faster CPU's? I don't think we mentioned this before.
    1999 Black Pontiac Trans Am
    CarPC's in F-bodies
    How To Relocate Climate Controls on the 97-02 F-body Cars
    (AMD Sempron 3000+, Opus 150)
    Car PC system is out, Alpine system is in.
  5. #245
    Sep 2006
    The software part requires a minimum of Pentium4/Athlon. With all the software audio processing running on a Pentium M 1.8 I have, ~50% CPU usage. I was told that my EPIA would choke. I never tried it, but I believe it. That's why I am upgrading.
  6. #246
    _
    Mar 2004
    Little Elm, Texas
    yeah - because of the processing power needed to do all processing, I don't think the vista requirements will be an issue.
    Jan Bennett
  7. #247
    Oct 2005
    Hou. TX
    Someone asked about why it's better to have an analog volume control as opposed to digital (or PC controlled). I think I found out why.
    Currently, (with XP) the WDM volume control lowers the volume by taking away bits, or reducing the resolution. Playing back music at low volumes using software volume control will not sound as good as it would if you were to leave the data alone (and not decrease the resolution) and attenuate the analog signal using high quality potentiometers or volume chips like the Cirrus Logic 3310 or 3318 or the TI/Burr Brown PGA2310 or PGA4311.
    Vista will adjust the volume using internal floating point values rather than integer. So it does not reduce resolution as XP did.
    CarPC's in F-bodies
  8. #248
    _
    Mar 2004
    Little Elm, Texas
    For Windows, that makes sense. However, the person I heard it from wasn't referring to Windows based. He's going to be here tonight, I'll ask him then.
    Jan Bennett
  9. #249
    Oct 2005
    Hou. TX
    So Red, your planning to upgrade your PC to a faster unit and run a non Windows based OS like Linux or a variant of Linux?
    CarPC's in F-bodies
  10. #250
    _
    Mar 2004
    Little Elm, Texas
    already upgraded (check specs and work-log)
    currently, not looking to run Linux or a varient because I wouldn't have the software to do tuning avaliable.
    Jan Bennett
  1. diy usb audio with optical in / out
    By Raas in forum Off Topic
    Last Post: 05-01-2008, 04:03 AM
  2. USB audio box with optical and stereo
    By craigyb in forum General Hardware Discussion
    Last Post: 03-13-2008, 06:29 AM
  3. usb to mini 3.5mm audio?
    By scott_fx in forum Input Devices
    Last Post: 02-10-2007, 09:08 PM
  4. FS: Edirol UA1X USB Sound Adaptor
    By 94 Cobra R in forum Classified Archive
    Last Post: 06-29-2005, 07:51 AM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
