Page 26 of 38 FirstFirst ... 161718192021222324252627282930313233343536 ... LastLast
Results 251 to 260 of 377
Thread: audio over USB v. optical
  1. #251
    Oct 2005
    Hou. TX
    Quote Originally Posted by RedGTiVR6 View Post
    currently, not looking to run Linux or a varient because I wouldn't have the software to do tuning avaliable.
    So then is it XP or Vista you plan to run?
    1999 Black Pontiac Trans Am
    CarPC's in F-bodies
    How To Relocate Climate Controls on the 97-02 F-body Cars
    (AMD Sempron 3000+, Opus 150)
    Car PC system is out, Alpine system is in.
  2. #252
    Constant Bitrate Felix509's Avatar
    Feb 2007
    Lafayette, LA
    Bandwidth issues are as follows:
    USB1.1 = 12MB/s per controller
    USB2 = 480MB/s per controller, several motherboards have 2 USB2 controllers now.
    Just for the audio data, there is other data sent across the USB line also.(timing and packet stuff??)
    16 bit at 44.1KHz(44,100 samples per second), cd standard rate, is 16 x 44100 = ~0.71 MB/s for mono -- 1.42 MB/s in stereo. USB1 is plenty good for this.
    24/96 is 4.6 MB/s mono so 9.2 MB/s Stereo. USB1 would be at or over its limits..
    USB2 could handle over ~40 channels of 24/96 audio then..
    These numbers are theoretical and I am sure there is more to the transfers than this..
    Laters
    Ours is the age that is proud of machines that think and suspicious of men who try to.
    ___________________________________
    Current SYSTEM
    AMD64X2 2.5
    Xenarc
    ZAPCO DSP-6
    ARCAUDIO SE Amps
    Rainbow Profi CS365 & Profi Vanadium 12"
  3. #253
    _
    Mar 2004
    Little Elm, Texas
    it's a good basis to start from though. Thanks for the info Felix!
    Jan Bennett
  4. #254
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by JasonWW View Post
    I'm sticking to XP until Vista has more support and has more bugs worked out.
    In order for me to switch, every single program I need to run on the computer would have to run flawlessly (relative) on Vista.
    Just don't think that's possible right now.
    Jan Bennett
  5. #255
    Constant Bitrate 00christian00's Avatar
    Apr 2005
    Italy,Ancona
    Hi guys,
    I got a call to join the thread
    You do want to do sofware processing on 8 channel with a usb dac,actually I don't think it will be possible with any usb dac alone,but here are some hint from the idea of my second setup with 2 sound card(i then realized i could do the same with 1 card of mine).
    First you need a card with internal routing of audio,I had an audiotrak prodigy 7.1 lt and it was perfect for the task.
    You then route the windows audio to a windows virtual input(using WDM audio) that's all the first card will do,then you can send the output with the usb dac.
    You need a vst host that can process wdm audio,since asio can handle one sound card at a time,and brainspawn forte will be perfect for this.It's a host vst rack based that can do everything you haver dreamt for.
    You simply take the audio from the wdm input,process it any way you want and then you direct it to the usb dac.Simply Enough!
    For vst i suggest the following : antares filter(best xover ever),voxengo delay and voxengo curveeq(this is too cool).Too bad they aren't freeware except delay.
    Btw,why is usb dac the only option?
    Download our catalogue here :
    http://www.noboringstuff.com/catalogoweb.zip
  6. #256
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    I have a prodigy 7.1 hifi I am already doing this with too but with a program called Console to string the VST plugins together such as Frequency Allocator for filtering, voxengo for delays, and have not decided on eq yet.
    We want a USB DAC for external reasons, might not have room for a PCI card. Also, a DAC to eliminate things from the signal path that might alter the sound in an unwanted way and get nothing but a super high quality signal out. A good high quality stereo DAC will put any soundcard to shame, the problem is doing it with multiple channels and with ahigh voltage output to reduce unwanted noise that could be picked up from having a low signal voltage.
    The trouble is that multiple channel DACs just don't exist as far as all the info we have or haven't found. Do you know of a multi-channel DAC? Or did you try using mutilple stereo DACs? Please explain your soundcard combined with a DAC setup. Just remember, we need to leave the PCI soundcard out though. I think we could do this with a program called Virtual Audio Cable which allows you to capture the audio stream and send it to any app. It's a virtual soundcard.
  7. #257
    Apr 2005
    Italy,Ancona
    My previous setup was 2 pci card,but should work the same with one pci plus usb dac.But i don't know of any usb dac that will allow audio routing,so you will be forced to use at least one pci,unless you find a way.
    Multiple stereo dac should work in theory,but in reality you will surely find many problems,conflict and so on.
    BTW I am now connected with my 1820m with external rack where the dac is with an external psu,so i get the best of both worlds,output voltage is more than normal headunit,everything is connected in balanced.
    Altough i don't think like suggesting it to other people,drivers are buggy and i had to tweak some circuitry inside to make it sound good,altough its awesome spec and still now i think it miss some punch-bass.
    However the whole thing of having the dac external for space saving is a little without meaning,if the reason of that is that you want to use some epia mainboard,i currently have setup the system for a simple 2 way plus subwoofer and my celeron d 2.4ghz is suffering a lot,and when watching video it stay at 100%,so you won't be surely able to use it with an epia,if you want to run it on 3-way system.
  8. #258
    Maximum Bitrate Ruffy's Avatar
    Sep 2006
    Georgia
    havent read it. but someone was trying to do this
    http://didnt.doit.wisc.edu/audio/DDD...ddac16usb.html
    below he mentians a multi channel dac in the future.
    Car : 00' Chrysler 300M
    Speakers : Rainbow Audio SLC 265 | Subs : Diamond Audio D6 12" Subs X2
    Amp's : Hifonics ZXi 6006 AB | Hifonics BXi 1606 D
    CarPC: HP Laptop AMD Sempron 3000+ | 1.5GB RAM | DVD+RW | 80GB 5400RPM HD | ATI R200 Video
  9. #259
    _
    Mar 2004
    Little Elm, Texas
    christian - I think that if you can read the thread you will understand why the conditions are set forth as they are. We've been over and over and over the conditions. I think that it will make some sense why we have the conditions set forth that we do.
    I'd also see this thread: audio over USB v. optical
    It will help to explain the tuning side of this.
    Jan Bennett
  10. #260
    Maximum Bitrate Dennis5587's Avatar
    Nov 2004
    NY
    so... is anyone still interested in just having 4 DAC's and figure it all out through software?
    Cause my friend was telling me about "fmod", which you can aparently do all of this with... The programming would have to be in either C, C++, C#, or Visual Basic, so I'm not sure how friendly it would be for different setups...
    I'll know more this weekend when he can show me some of what he's done, and whether or not it possible..
    Basically Fmod is able to use Vst's, Dsp's, and is capable of outputing to multiple sound cards... so it sound's like it will be everything we need...
    http://www.fmod.org/
    2006 Mazda 3
    Behringer DCX-2496
    JL500/1 JL10w6v2
  1. diy usb audio with optical in / out
    By Raas in forum Off Topic
    Last Post: 05-01-2008, 04:03 AM
  2. USB audio box with optical and stereo
    By craigyb in forum General Hardware Discussion
    Last Post: 03-13-2008, 06:29 AM
  3. usb to mini 3.5mm audio?
    By scott_fx in forum Input Devices
    Last Post: 02-10-2007, 09:08 PM
  4. FS: Edirol UA1X USB Sound Adaptor
    By 94 Cobra R in forum Classified Archive
    Last Post: 06-29-2005, 07:51 AM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
