Page 31 of 38 FirstFirst ... 212223242526272829303132333435363738 LastLast
Results 301 to 310 of 377
Thread: audio over USB v. optical
  1. #301
    Mar 2006
    WOW!!!! Thanks alot Hippohifi!!!!! I just downloaded and started using it. What a great find.
    Chef
  2. #302
    _
    Mar 2004
    Little Elm, Texas
    I could have sworn I sent you a link to this thread a while back in a PM:
    Software options for Tuning
    All of the software side of this is covered in that thread, and then some.
    There are a few issues with foobar and asio4all, they are discussed in that thread as well.
    Jan Bennett
  3. #303
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    Hippohifi-
    Although the foobar method is a very nice free option for the crossver end of it, it only does music/ will not work for videos/DVD's, and it is not as universal. Pluss more front ends support winamp (including Road Runner). There is no frontend based on Foobar even though it was asked several times, no one showed any interest.
    So did you get a chance to try it with the Allocator and Console Demo's?
  4. #304
    Newbie HIPPOhifi's Avatar
    Feb 2007
    durwood, I completely understand considering I use Road Runner in my carPC.
    I am sure I can get it to work for Winamp considering foobar is fine. Let me take a look at a few plugins and have a play.
    Similarly with Allocator, report back soon...
  5. #305
    Feb 2007
    Had a quick play, currently stuck on routing input channel on console. Attempted to use Virtual Audio Cable but the UI is terrible and makes no sense to me, ideas?
  6. #306
    Feb 2007
    Good News Again
    Good News Again, working perfectly with the following setup. Even better separation in frequencies with Frequency Allocator.
    Hardware
    PC with 32bit Vista
    2 HIPPOhifi Bloats
    Sennheiser HD650's
    Software
    ASIO4ALL 2.7
    Winamp ASIO Plugin
    Winamp
    Virtual Audio Cable 2
    Frequency Allocator
    This setup took a little longer to put together, the major issue as you can see from my previous post was routing the output of Winamp into the input of Frequency Allocator. Console was an option but it seemed a little complex, instead I used Virtual Audio Cable 2. Virtual Audio Cable 2 required no setup, excellent tool. Have to admit the verbal trial warnings in Frequency Analyzer started to annoy me.
    More than happy to put together a pdf or alike with installation instructions on my website if people purchase the bloat for this specific task.
    Any q's?
  7. #307
    Sep 2006
    Excellent news. I had never used Virtual audio cable, but it was recommended for setups/soundcards that didn't have routing but into the drivers. This is great news. A step forward, I think the issue we see is having to use 4 USB ports for a 4-way setup.
  8. #308
    Feb 2007
    Quote Originally Posted by durwood View Post
    True, I never envisioned 4 Bloats being used on the one PC but it would certainly look good once installed.
    There isn't really a way around this either considering each bloat uses near maximum power supplied over USB. This enables the DACs/amps to perform at peak. Can always add a powered USB hub or similar product.
  9. #309
    Constant Bitrate Felix509's Avatar
    Feb 2007
    Lafayette, LA
    FANTASTIC! This project definitely has a Bright future!!
    So Mr Hippo,(smiling as I type that) USB bandwidth?? The PCM2707 is USB1.1, will running multiple DAC units give problems(pauses in music stream, etc.) Would the Source computer need seperate USB controller cards for each unit??
    Laters!!
    Ours is the age that is proud of machines that think and suspicious of men who try to.
    ___________________________________
    Current SYSTEM
    AMD64X2 2.5
    Xenarc
    ZAPCO DSP-6
    ARCAUDIO SE Amps
    Rainbow Profi CS365 & Profi Vanadium 12"
  10. #310
    Oct 2005
    Hou. TX
    If this works out, maybe you could offer a discount for folks buying multiple Bloats at one time. Or maybe even a group purchase price.
    Also, and I may just not be thinking here, what is the purpose of using ASIO in this particular application? Is it needed or does it just increase the sound quality?
    EDIT: Ah, I believe it is a neccesary part to get this whole thing working.
    1999 Black Pontiac Trans Am
    CarPC's in F-bodies
    How To Relocate Climate Controls on the 97-02 F-body Cars
    (AMD Sempron 3000+, Opus 150)
    Car PC system is out, Alpine system is in.
  1. diy usb audio with optical in / out
    By Raas in forum Off Topic
    Last Post: 05-01-2008, 04:03 AM
  2. USB audio box with optical and stereo
    By craigyb in forum General Hardware Discussion
    Last Post: 03-13-2008, 06:29 AM
  3. usb to mini 3.5mm audio?
    By scott_fx in forum Input Devices
    Last Post: 02-10-2007, 09:08 PM
  4. FS: Edirol UA1X USB Sound Adaptor
    By 94 Cobra R in forum Classified Archive
    Last Post: 06-29-2005, 07:51 AM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
