Page 34 of 38 FirstFirst ... 242526272829303132333435363738 LastLast
Results 331 to 340 of 377
Thread: audio over USB v. optical
  1. #331
    Constant Bitrate Road_Dog's Avatar
    Nov 2006
    USA, Oregon
    Quote Originally Posted by Mrbmw99 View Post
    The line inputs will be used for a switching/mixing capability (like a normal HU). There are several different sources that need to be switched between, such as the internal AMFM radio tuner, the XM or Sirius tuner, the 2 AV input sets on the back of the unit, etc..
    I'm just looking for a good USB design to use for this. Most USB devices on the market now are only 1 line input, so those don't work.
    - Brett W
    Have you looked at: http://www.controlanything.com/Merch...gory_Code=VIDS ? I am thinking of one of these to switch my AM/FM tuner board, Sirius Sat radio, and few other things.
    Also, they have massive number of relay boards.
    Road_Dog
  2. #332
    Constant Bitrate Felix509's Avatar
    Feb 2007
    Lafayette, LA
    Wellllllllllllllllllllllll///
    I think that all of the options for a source are available in the computer.... AM/FM has several USB modules that are controlled via software, and XM has XM PCR that is a USB interface.
    I guess I cannot think of anything that would be outside of the PCs realm for a source....
    Ours is the age that is proud of machines that think and suspicious of men who try to.
    ___________________________________
    Current SYSTEM
    AMD64X2 2.5
    Xenarc
    ZAPCO DSP-6
    ARCAUDIO SE Amps
    Rainbow Profi CS365 & Profi Vanadium 12"
  3. #333
    Maximum Bitrate Megalomaniac's Avatar
    Jan 2006
    The Colony, TX
    Subscribed.
    Where are you right now on this new SQ EQ device for the carpc? Anytime soon? I'm lookin into the Alto Drive 30 right now, i scratched the 701 plan i had.
  4. #334
    _
    Mar 2004
    Little Elm, Texas
    SQ EQ device?
    What do you mean specifically? Software EQ?
    Jan Bennett
  5. #335
    Jan 2006
    The Colony, TX
    Quote Originally Posted by RedGTiVR6 View Post
    SQ EQ device?
    I havent read this whole thread yet. judgin by the first page. You are/were trying to create an prototype software and a USB hardware for the audio for an SQ audiophile who want to get the best sound as possible out of their carPC. correct?
  6. #336
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    Is anyone still working on this? I thought that hippohifi might have had the answer, but we still don't know how well this solution works with the eq's. Also for external audio ie. for a fm tuner, couldn't you still input via the mic in on board soundcard?
    Sorry if I have misunderstood the soundcard input thing, I have just read all the corresponding threads this morning and still trying to get my head around all of the information in them.
    @ Red: Have you made any more progress? Back eariler in the thread you said you were going off to do your own thing? Are you any closer to a solution?
  7. #337
    Newbie HIPPOhifi's Avatar
    Feb 2007
    Quote Originally Posted by meddler View Post
    Software EQs would be a problem, are you refering to something else?
    Yes you can do this, furthermore is the source is not analogue you can use virtual audio cable to reroute the audio path from one device to another.
    Yep heaps of information in this one.
  8. #338
    Oct 2007
    ok i think i have the solution i have an 8 channel usb soundcard all in one...with 8 left/right outputs and one usb input....it also has 8 24 bit dacs...thats right one per channel...now im sure this thing has **** poor voltage outs...so why not get a six channel pg linedriver and a 2 channel one...that would every channel to 8-10 volts! next step would be setting all the processing up on your computer and there you go...nice clean install and everything you need....let me know what yall think
    http://store.mp3car.com/GIGAPort_AG_..._p/com-066.htm
  9. #339
    Nov 2007
    I'd try it without the line drivers first. The simplier the audio chain the better.
    PS what audio chip is the GIGAPort AG using?
  10. #340
    Oct 2007
    idk ...i scratched that idea...found out it really only has 16 bit dacs in it...i need at least 24 bit...so still searching
  1. diy usb audio with optical in / out
    By Raas in forum Off Topic
    Last Post: 05-01-2008, 03:03 AM
  2. USB audio box with optical and stereo
    By craigyb in forum General Hardware Discussion
    Last Post: 03-13-2008, 05:29 AM
  3. usb to mini 3.5mm audio?
    By scott_fx in forum Input Devices
    Last Post: 02-10-2007, 08:08 PM
  4. FS: Edirol UA1X USB Sound Adaptor
    By 94 Cobra R in forum Classified Archive
    Last Post: 06-29-2005, 06:51 AM
  5. Replies: 4
    Last Post: 04-06-2004, 09:52 AM
