Page 6 of 38 FirstFirst 12345678910111213141516 ... LastLast
Results 51 to 60 of 377
Thread: audio over USB v. optical
  1. #51
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    I think if we want a solution sooner than later, we could go the route of re-engineering something already available. I think slapping a line driver on the end of a pro audio piece of equipment would be the easiest. Or we can do it from the ground up taking a long time.
    I will admit, I don't have the cash to throw at something like the F1....at least right now. I even had to be coaxed into buying my H701 by my buddy last year.
    Now I have some VERY expensive obligations going on in the next year and a half and unless I win the lottery I don't see my financial status changing anytime soon. Typical- In other words, I want what I can't have. I know that inexpensive only gets you so far, but it should be reasonable in some respect to get this off the ground.
  2. #52
    _
    Mar 2004
    Little Elm, Texas
    hehehehe
    I'm all for taking an existing piece. Problem is, we first have to find a card that has the needed outputs and can be adapted to run on 12v DC.
    Then from there we need to be able to swap out the parts...because quite honnestly, most of the RCA sockets I've seen on the USB/Firewire cards are maybe 5 cent parts.
    Jan Bennett
  3. #53
    Sep 2006
    Quote Originally Posted by RedGTiVR6 View Post
    Agreed. What about a dongle type connection similar to the cards with breakout boxes? Then you could have optional cables. I jsut don't know how good it would be to have unshielded wires that close to each other though.
    I was going to say does it really need 12V? I guess if it's external it would be the easiest. Either way to get a high voltage output, there has to be high enough voltage rails going to the output opamps to allow for headroom. The X-Merian only has +/-8V rails, which is created by a DC-DC conversion of wither the 3.3 or 5V voltage from the PSU. Even using 12V, you still need to have a DC-DC PS conversion to get +/- voltage rails high enough to allow for a high preamp voltage. I guess I answerd my own question.
  4. #54
    Oct 2004
    NY
    what do you think of the idea I mentioned of using an optical out from the pc, or firewire even, into a pro audio da converter?
    apogee rosetta 800 very expensive, but looks like it would build a sick system..
    then theres this, which looks much more affordable...
    this looks like it would do the job well too...
    any one of these would require rengineering of the power supplies, & these may be too extreme for anyone here even, but this is where my head is going.... help
    I'm in the process of buying a house right now, & if I can pull this off without spending a small fortune I'd welcome that... it's just that I'm a sick boy, & when I look at something, I always want to see what's better, I mean if I'm going to go for "this", then for just a bit more I could go for "that", but once I'm up to "that", I may as well just go for "this".... well once I'm up to "this", then **** it, might as well just go for "this" & get it over with.... anyone understand that???
    the way I see it, the f1 isn't the ceiling anymore
  5. #55
    Maximum Bitrate Dennis5587's Avatar
    Nov 2004
    NY
    wouldn''t this all be accompolishable via just software... like why not just get 5 silverstone DAC's, and then figure out how to route them through software...?
    At least this way it is pretty cheap for you choose your own level of involvement, you can add on as you go... if you only want 3 sets for your tweets, mids, and subs, then thats all you need, costing you only $300 in hardware... but if you want to have tweets, woofer, rears, and subs, then you get an extra one....
    Or am I completely off?
    2006 Mazda 3
    Behringer DCX-2496
    JL500/1 JL10w6v2
  6. #56
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by turbocad6 View Post
    I'm not keene on using optical for the jitter issue. I've learned that optical isn't as desired as I thought it once was for the jitter problems. And to boot, not all mobos have optical outs right now.
    Regarding Firewire, I'm not so sure about it right now for a first piece. Why? Not all mobos have fire wire (for instance- the board I'm running now in the car doesn't have it). For this first step, I think it needs to be on a platform that will suit the most people. Once we get that down, THEN we can move onto other options.
    I'm really worried about size there. I for one don't have anywhere left to put something like that in the car. At that point, we might as well go with the DBX drive rack and just modify the PSU like people have done in the past.
    Jan Bennett
  7. #57
    Sep 2006
    I just bought a house, a ring, and now have a wedding to pay for ahahahah.
    The F1 is only a starting point. hehehe
    We have already entered the realm of pro audio, that is almost limitless when you include software. What is better though? A DAC or Pro Audio equipment used to record the material in the first place? This thread kind of got derailed a while back. hahahaha. Wasn't this suppsoed to be about SPDIF v USB DAC's?
  8. #58
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by Dennis5587 View Post
    we're not worried about the tuning aspect of this. We're worried about the hardware side of things.
    Sure, you can get 5 seperate silverstone dacs, find somewhere to put them, find somewhere to wire up 5 usb cables, and power them, etc. We're talking about making what the market is missing right now.
    Jan Bennett
  9. #59
    Sep 2006
    Good point. Something the size of our H701 brainboxes or smaller.
  10. #60
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by durwood View Post
    yes, it was...lol
    I'm realizing that even though I'm trying to keep the idea on a path, it keeps wandering...
    Ah well, at least it's generated some interest. I know what I'm going after and I'm going to try and find a way to make it happen. We'll see what others come up with.
    Jan Bennett
  1. diy usb audio with optical in / out
    By Raas in forum Off Topic
    Last Post: 05-01-2008, 04:03 AM
  2. USB audio box with optical and stereo
    By craigyb in forum General Hardware Discussion
    Last Post: 03-13-2008, 06:29 AM
  3. usb to mini 3.5mm audio?
    By scott_fx in forum Input Devices
    Last Post: 02-10-2007, 09:08 PM
  4. FS: Edirol UA1X USB Sound Adaptor
    By 94 Cobra R in forum Classified Archive
    Last Post: 06-29-2005, 07:51 AM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
