Page 8 of 38 FirstFirst 123456789101112131415161718 ... LastLast
Results 71 to 80 of 377
Thread: audio over USB v. optical
  1. #71
    _
    Mar 2004
    Little Elm, Texas
    Jan Bennett
  2. #72
    Maximum Bitrate Dennis5587's Avatar
    Nov 2004
    NY
    Quote Originally Posted by IC-C30 View Post
    Damn..... Should've had a look at this thread from the beginning.... Interesting! And if the DAC gets built, you can be sure I'll take one.... Hell, now I'm gonna read the whole thread
    It becamse a good read withing hours....
    2006 Mazda 3
    Behringer DCX-2496
    JL500/1 JL10w6v2
  3. #73
    FLAC XC-C30's Avatar
    Jun 2006
    Abele, Belgium
    aaaah a 10-channel mono out DAC..... way to go.... WHEN WHEN WHEN I'll stick with the ESI gigaport for now....
    Xenia & Isabelle, totally in love!
    'T SQiekenkot: VOLVO 740GL 2.3
    CarPC: none at the moment
    CLARION HX-D2
    CLARION APA4300HX => Fountek NeoCd1.0 + TB W4-1337SD
    CLARION APA4300HX => CSS Trio8
    CLARION APA2100 => Dayton IB385-8
  4. #74
    Oct 2004
    NY
    Quote Originally Posted by JC-S60 View Post
    Aparently I wasn't all that knowledgeable about usb audio
    If the software that is going to be used can support output to multiple audio devices, you could just use 4-5 stereo dac's on one PCB, with one PSU and a USB hub to only use one USB connection (if bandwidth allows for this, but I guess it should).
    That way your computer will recognize 5-6 devices (dac's +hub) but you can use them the way you want!
    Even using some outputs for different audio output/multi zone (wireless headphones?)...no problem as the computer sees the different channel pairs as different devices!
    Just my 2 cts
    Joachim
    we really need to know if multiple usb dac's can be used simultaneously to begin with.... this would make off the shelf very practical...
  5. #75
    Jun 2006
    Abele, Belgium
    Wouldn't that require some software-adjustment, for tweaking the DAC's simultaniously?
    CLARION HX-D2
  6. #76
    Nov 2004
    NY
    I'm not totally caught up on my software... but can you take a wave file, and split up the wave by frequency then send it to different sound cards?
    Not different channels, I know you can do this with console... but what about different channels on completely different cards?
    2006 Mazda 3
    Behringer DCX-2496
    JL500/1 JL10w6v2
  7. #77
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    I was thinking along the same lines but I don't know enough about USB dacs either. The take something like the circuitry of an audiocontrol matrix and hack it into the same enclosure and make the opamps they use interchangeable.
    But can a USB DAC be recognized in ASIO apps? Does ASIO4ALL work with these USB dac's? Who has a DAC, or who has multiple DACs laying around that they can test this with? Bueler....Bueler...anyone...Scott_fx?
    Added:
    Quote Originally Posted by RedGTiVR6 View Post
    yeah - congrats!
    Thanks!
  8. #78
    Nov 2004
    NY
    ...i have a silver stone laying around doing basically nothing until like may when i put a carputer in my new car (assuming i don't get the 701)
    2006 Mazda 3
    Behringer DCX-2496
    JL500/1 JL10w6v2
  9. #79
    Oct 2004
    NY
    I have seen mention on one of the audiophile sites of a review of one of the usb dac, & there was mention by the reviewer of how 3 of these would build an awsome home theater.... if this is a go then most problems are over, with the exception of higher line voltages, but this can be modded for sure no problem I think....
  10. #80
    Nov 2004
    NY
    sweet, if you find that review post it up, I could use a good read (stupid sociology)
    2006 Mazda 3
    Behringer DCX-2496
    JL500/1 JL10w6v2
  1. diy usb audio with optical in / out
    By Raas in forum Off Topic
    Last Post: 05-01-2008, 04:03 AM
  2. USB audio box with optical and stereo
    By craigyb in forum General Hardware Discussion
    Last Post: 03-13-2008, 06:29 AM
  3. usb to mini 3.5mm audio?
    By scott_fx in forum Input Devices
    Last Post: 02-10-2007, 09:08 PM
  4. FS: Edirol UA1X USB Sound Adaptor
    By 94 Cobra R in forum Classified Archive
    Last Post: 06-29-2005, 07:51 AM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
