Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 42
Thread: Simple and Clean Remote Laptop Power Switch
  1. #21
    Jun 2008
    Here is a couple after pics of my job.
  2. #22
    Constant Bitrate WarDriver's Avatar
    Apr 2006
    Central VA
    Quote Originally Posted by AltimateX View Post
    Works great!
    Nice write-up Wardriver. Thanks for the effort!
    Glad it worked...
    -WarDriver-
    Server Administrator
    Outdoor Nut
    My DC to AC Inverter Mod
    My Laptop Remote Switch
  3. #23
    Jan 2005
    idea
    Waveteck: Heres something i was thinking about concerning the start switch vs. startup controller issue. Most people want the laptop to start up and shut down on ignition because its cool and they dont want to have to press a button. Yet, the power switch is the most reliable method of shut down and power up.
    Possible solution: use the hard power switch mechanically with the cars automatic door lock system. In my convertible when I hit LOCK on my remote the two door pins lock and so does my trunk..and even my gas cap. When I hit unlock, the inverse happens. Why not hook a very light touch power switch as yours to one of these mechanisims? While at the same time retaining a spare ..say under your drivers seat just in case you have to reboot or shut down or whatever? This even had the added advantage that your computer starts to bootup/wake as you are walking up to the car before you even get inside. Has this been discussed?
    Pros and cons? (other than the actual install which i would asume could get hairy)
    Leo.
  4. #24
    Apr 2006
    Central VA
    Quote Originally Posted by BMW DZYN View Post
    The install shouldn't be too bad - you could use a relay and just use a simple relay. You would just hook your "line" and "load" terminals to your laptop.
    You'd need to test of course - different cars pulse differently not to mention you'd have to run the wires down. (which shouldn't be an issue if you can get your hands on a diagram) I would say that it would work good for start up or standby...definitely worth investigating. You'll want to make sure that each time you lock you doors you don't trip your relay - so that might involve a 50 cent diode available at any Radio Shack.
    Let us know how it goes.
    -WarDriver-
    Outdoor Nut
  5. #25
    Jun 2008
    Hey guys, wondering if you can shed some light on this, picture quality is crap sorry. Pretty much I am lost, the inside of my laptop looks nothing like what you have. Its an earlier Dell model.
    On my start button setup, it is a small board with 2 very small buttons, the one on the left is for the power on/off. Here is what it looks like.
    This is the backside of it..
    This is where it plugs in..
    HELP!!!!
  6. #26
    Apr 2006
    Central VA
    Quote Originally Posted by 2jzlex View Post
    I recall seeing one like this when I tore down a dell. Use a multimeter and figure out which contacts produce connectivity when pressed. Then solder off of those pads.
    -WarDriver-
    Outdoor Nut
  7. #27
    Aug 2008
    I am about to do this to my acer aspire one, but I am very scared... haha... anyone live near deptford NJ and maybe want to help?
    i have never soldered before in my life... well maybe once. but not on a brand new computer..
    Not my pic, got it off internet, ive opened it before, when i do again ill get better pics but the power button is the little thing at the very top right hand corner. how hard do you think it will be?
  8. #28
    Apr 2006
    Central VA
    Soldering is not hard...you just need some practice.
    Radio Shack sells a cheap-o kit for like $8 that should get you started. Depending on the switch mechanism the tip may be too wide.
    As for tips on how to solder you should hit up YouTube. There is a lot of good material on there.
    As for the switch - I cannot tell you the best way to mod your new PC...just use some common sense.
    -WarDriver-
    Outdoor Nut
  9. #29
    Oct 2004
    Stockholm
    Please help with eeepc 901
    Hi,
    I will like to make this mod but I dont know where to solder the wires
    I have a Asus 901.
    Please if there is sameone out there that knows where to connect the wires plese let me know.
    Regards
    Heliodoro
  10. #30
    Apr 2006
    Central VA
    Heliodoro
    Check the continuity between the 4 pads when the button is pressed.
    -WarDriver-
    Outdoor Nut
  1. Simple and clean DC to AC inverter remote switch on mod
    By WarDriver in forum Power Supplies
    Last Post: 06-03-2011, 10:20 AM
