Results 1 to 8 of 8
Thread: Laptop with no working battery.
    Sep 2008
    So I got a laptop and the battery doesn't hold any charge. Not even for a sec anyway the auto start switch wont work for me because it wont power off the unit. Anyone have any tips they can through my way?
    Elsewhere
    If it will work w/ your laptop, use a Carnetix unit.
    Check the DC power output on the AC power brick.
    How about the Wiki?
    Sep 2008
    Quote Originally Posted by DarquePervert View Post
    Is there a DIY way to do this?
    Nov 2007
    You can probably get a new battery for cheap, from ebay or from a shop like BTI.
    Elsewhere
    Quote Originally Posted by Forge View Post
    Is there a DIY way to use a Carnetix unit? That sort of is a DIY procedure.
    Now, if you want to build your own, it's certainly possible, but you're better off purchasing one to save yourself some money and headaches.
    So is checking the output voltage on your AC power brick. You have the power brick. You look at the label on it. You determine the output voltage.
    Doesn't get more DIY than that.
    How about the Wiki?
    Jul 2008
    Try new battery like G4 15" or G4 12"
    Variable Bitrate rizaydog's Avatar
    Nov 2007
    North Central PA
    You could also manually shut down before you turn your car off. When you get some $$, buy a battery.
    Nov 2008
    laptop withe no battery
    the bes think is that you make a sigle connexion direct from the car battery whithe a switche on the - not the + so you can deside whenyour laptop go of
  1. Powered Portable CarPC with laptop battery?
    By mrlover in forum Power Supplies
    Last Post: 09-30-2006, 07:28 PM
  2. What could cause this problem? (laptop related)
    By Rocky388 in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 09-17-2006, 04:17 PM
  3. Can i power my laptop through my battery port?
    By Sickkindaheadd in forum Power Supplies
    Last Post: 03-06-2006, 06:12 PM
  4. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 10:31 PM
  5. WTB: Laptop Over 500mhz with a working battery
    By Gilly1998 in forum Classified Archive
    Last Post: 09-21-2004, 09:36 AM
