Ok so here is my newbie attempt at a diagram outlining what I think will be the wiring for my carpc's Power .. I havent found to many diagrams for the p1900 wired to a laptop especially through an auto adapter. please do let me know if its incorrect.
I am still going to Use the P1900 as a startup / shutdown controler for the pc but since I need to run the dell through the lind auto adapter I am running from the battery to the p1900 to the lind auto adapter then to the laptop. Im not certain about the acpi wire .. is on a laptop does it go to the power button? Is it ok to have an inline momentary switch mounted in my dash to be able to reset the pc in the event of a system crash / freeze ... Also is the main on / off switch ok on the ignition lead ?
http://i131.photobucket.com/albums/p...CarPcPower.jpg
