Results 1 to 10 of 11
Thread: How to turn on laptop
    Newbie elBradford's Avatar
    Mar 2008
    Utah
    I'm going to simply use a car power adapter with a relay that will provide power to the laptop when the acc is high. I'll then tell Windows to shut down the computer after an amount of time. The only problem I have is turning it on. If I standby or hibernate, all I need to do is, say, press a key on a keyboard and it will turn on. Any way to automate that? What happens when a key is pressed?
    I'm not interested in a special power supply, and really the only thing that is left is figuring out how to turn ACC into a keyboard press.
    monkey stole my pen
    My Worklog
    Elsewhere
    Search around the forums.
    There are a number of ways to pull this off. It's all about which method will work best for you.
    How about the Wiki?
    Mar 2008
    Utah
    Quote Originally Posted by DarquePervert View Post
    Isn't there an active thread about this kind of response and how unhelpful it is? You could try searching for it.
    All I've found by searching is about controlling the power button. I am not going to go into that. I know a computer capable of S3 sleep can be turned on by certain USB conditions. I am asking if anyone knows of a way to wire a usb device to ACC that will cause this USB event.
    Edit: This could work, but I was thinking of USB instead of RJ45 because my laptop probably won't support WOL.
    monkey stole my pen
    My Worklog
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Use an ipac. It's a keyboard simulator that you can wire a switch -or a relay to. Just remember to use a momentary relay or you'll have continuous keypresses.
    Want to:
    Low Bitrate war085's Avatar
    Mar 2010
    Quote Originally Posted by Bugbyte View Post
    Hmmm ... Let me absorb this, I use this ipac to simulate a keyboard press, I connect an external button, so once I press the button, the laptop will wake up on USB ?
    Is this the IPAC? :
    Low Bitrate atrixstars's Avatar
    Oct 2006
    I have a "hard wired" setup. One of a kind. But you can checkout: http://www.xobyte.com/
    My CarPc Blog (<This is outdated. I have updated to a fully running Carpc System)http://acurafuse.blogspot.com
    Elsewhere
    Quote Originally Posted by elBradford View Post
    Ironic that you complain about an unhelpful response, yet you do some digging and locate options for your situation....
    How about the Wiki?
    Dec 2010
    These are the steps I take: 1) turn laptop off. 2) connect lcd tv to laptop via vga cable. 3) Set lcd tv to vga input. 4) Turn on laptop.
    The lcd tv shows the bios screen and loading windows screen perfectly fine. When windows loads, the lcd tv goes blank and says no signal.
    I'm using windows 7 ultimate. Please help
    Dec 2010
    Forum's dead useful. Kind of hard to find these genuine commentors nowadays
    Low Bitrate 2009Prius's Avatar
    Sep 2010
    Any updates?
  1. Cant turn on laptop anymore :/
    By Dizzey in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 03-04-2008, 05:55 PM
  2. What could cause this problem? (laptop related)
    By Rocky388 in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 09-17-2006, 04:17 PM
  3. Replies: 55
    Last Post: 08-27-2005, 10:40 PM
  4. Replies: 3
    Last Post: 08-20-2004, 09:42 AM
