Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: 12v to 19v and some other question
  1. #11
    Oct 2010
    Quote Originally Posted by soundman98 View Post
    check the dc-dc power supplies first-- some have a low voltage cutoff adjustment-- these will shut off the pc more gracefully then other lvco's..
    so the powersupply to my laptop should include a voltage cutoff adjuster.
    I will consider this while browsing for my power supply
    thx
    then all i need to do is find a way to extend my screen and I should be up and running
    thx
  2. #12
    Raw Wave
    Nov 2009
    I agree with soundman - there are some great dc-dc converters with low standby currents and the handshaking required for graceful shutdown - ie, UPS functionality - PSU (dc-dc conv) sends "battery low - shutdown imminent"; PC starts shutdown; PSU shuts down when load drops or after a pre-adjusted time delay (or when battery is too low - ie, it collapsed quicker than anticipated).
    I have devised similar timed handshaking using the MW728 (it triggers a timer that hold power on), though just now I wondered if another great HVTO/LVCO kit can be internally tapped for handshakes. (The kit is the $22 Oatley Electronics (Australia) K227 - 12-24V Dual Battery Adapter For A Vehicle, but you need to solder & assemble and house it. But it has an adjustable voltage level & better delays than the MW728; uses a latching 80A relay; and only consumes 50uA else 500uA (0.5mA) with a LED. An has other potential mods given its circuit & operation description - not that I fully understood it!)
  1. AC-DC power pack question
    By GRUNT in forum Power Supplies
    Last Post: 05-08-2003, 09:36 AM
