Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Laptop Remote/External Power Switch Mod - NEED HELP!
  1. #11
    Dec 2009
    Quote Originally Posted by Tidder View Post
    Sounds like you're not checking for continuity. Sounds like you're checking for some type of reading. My multimeter doesn't close a switched circuit when checking... I don't think. Now I'm going to have to go try it.
    Yeah there doesn't seem to be a.setting for.continuity testing. It's a very simple meter. I guess I'll get my hands on one to use
  2. #12
    Dec 2009
    Ok, i was going about the testing improperly but it's done now, i found the two contacts that are in continuity when the button is pressed.
    Now to get a soldering iron with tips small enough to get the job done. So do I tin the wires w/ the solder, and then heat the contacts and put the tinned wires in contact w/ the iron contcats of the button circuit? What wattage soldering iron would be best for this job?
  1. Simple and Clean Remote Laptop Power Switch
    By WarDriver in forum How to Power a Laptop
    Last Post: 07-12-2012, 01:17 PM
  2. remote switch for laptop powerup
    By shawnmiller in forum Power Supplies
    Last Post: 08-10-2008, 07:50 PM
  3. External Laptop Power Switch HELP
    By jsmmao in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 07-28-2008, 02:40 PM
  4. Laptop remote switch - where to solder exactly ?
    By frontliner in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 02-14-2007, 08:18 PM
  5. FS: Compaq Laptop w/ Remote Switch Mod
    By WarDriver in forum Classified Archive
    Last Post: 05-12-2006, 11:45 PM
Tags for this Thread
