Results 1 to 10 of 12
Thread: Laptop Remote/External Power Switch Mod - NEED HELP!
    Dec 2009
    Hello guys, I am currently trying to follow WarDriver's Simple and Clean Remote Laptop Power Switch (Simple and Clean Remote Laptop Power Switch). I just took apart the laptop bezel and i've reached somewhat of a brick wall. I have little experience in soldering, so this only makes it tougher. The contact pads where I am supposed to solder are EXTREMELY SMALL and almost covered up by the button itself! The picture below is not great, but hopefully you can see what i'm talking about.
    Is it those little points on the corner that i would solder to, after testing the continuity? This is going to be a major pain in the *** lol.
    Dec 2009
    And this is a very close-up picture of the button as well
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Quote Originally Posted by azngujuonfire View Post
    Testing continuity will answer your own question.
    Depending on how the button is set up, you might be able to get away with only using one contact and have the other lead from your external switch go to laptop ground. You'll... have to test continuity.
    Tidder
    Try RevFE
    Dec 2009
    ha, yeah i'll be testing continuity shortly after i get home. The points are so small and almost hidden under the square that houses the button. There is barely any space under the button also.
    Ok so for the soldering portion, would i tin the wires and then heat the contacts and hold the tinned wire to it as it heats? What would happen if the solder also touched the metal square? I'm worried this may happen since there is so little room
    Constant Bitrate WarDriver's Avatar
    Apr 2006
    Central VA
    Test the contiguity - if that board comes out you might want to pull it out of the laptop and flip it over. Sometimes the pins go through to the bottom.
    -WD-
    -WarDriver-
    Server Administrator
    Outdoor Nut
    My DC to AC Inverter Mod
    My Laptop Remote Switch
    Dec 2009
    Quote Originally Posted by WarDriver View Post
    -WD-
    Wooow i never thought of that haha, how simple! I just pried the ***** out of the bezel b/c there were 2 screws that were the most stubborn biatches in the world to remove It was all for nothing, as there is nothing coming out of the back
    Ok so since i cannot use the back of the circuit board, this is going to be tough. is there anyway i can somehow "extend" those contact points further outward so that I can solder the wires to them? It is ok if there is solder on the blue board beneath the button right?
    Dec 2009
    Ok WarDriver, using a multi-meter, when i touched the leads to the top right and bottom left contacts, the laptop automatically turned on w/o having to push the button. Does that mean that these are the two contacts that "close" when the button is pressed? Any other combination of multimeter leads and contacts does not result in the laptop turning on.
    Apr 2006
    Central VA
    You should be checking for broken contiguity until the button is pressed.
    -WarDriver-
    Outdoor Nut
    Dec 2009
    When i put the lead on the bottom left contact, it turns on automatically. I tried pressing the button w/ the lead on that bottom left contact, but the multi-meter still reads ~0.000
    Sep 2003
    New Mexico, USA
    Sounds like you're not checking for continuity. Sounds like you're checking for some type of reading. My multimeter doesn't close a switched circuit when checking... I don't think. Now I'm going to have to go try it.
    Tidder
    Try RevFE
  1. Simple and Clean Remote Laptop Power Switch
    By WarDriver in forum How to Power a Laptop
    Last Post: 07-12-2012, 02:17 PM
  2. remote switch for laptop powerup
    By shawnmiller in forum Power Supplies
    Last Post: 08-10-2008, 08:50 PM
  3. External Laptop Power Switch HELP
    By jsmmao in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 07-28-2008, 03:40 PM
  4. Laptop remote switch - where to solder exactly ?
    By frontliner in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 02-14-2007, 09:18 PM
  5. FS: Compaq Laptop w/ Remote Switch Mod
    By WarDriver in forum Classified Archive
    Last Post: 05-13-2006, 12:45 AM
Tags for this Thread
