Results 1 to 10 of 19
Thread: DIY 5v, 2A tablet dc-dc charger for car??
    May 2010
    Herákleion, Iraklion, Greece, Greece
    hello guys. i have a tablet, that has external DC source. at the AC/DC transformer it says : outpout 5v 2A..
    so i want to make a dc-dc converter, to power the laptop in the car. My consern is this, will ANY 5v source do? or will i do a specific circuit, to give constant 2A?? (i really dont know how this thigns work...)
    the reason i ask, is, its a bit hard to find a ready car charger (that dosent use the usb port)..
    if just 5v, are enough, i was thinking to just use 5v Voltage regulators, becouse i want to avoid the switching power supply noise... anything i should look out for , here?
    Raw Wave
    Nov 2009
    IMO there are times you don't make sense...
    If you had a 5V source, you wouldn't need a regulator (assuming that 5V source can provide 2A).
    You could use a linear reg - they are available with 3A outputs else can be boosted with 2N3055 (or TIP2955 etc) transistors - but IMO why use all that volume and generate all that heat?
    I'd use a switcher - only crap designs have noise issues.
    And there are some nice HF designs (>1MHz) which apart from being so much smaller, IMO should be very difficult to emanate noise - eg eBay 360741066304.
    Otherwise the classic ~50kHz LM2577 else newer 400kHz XL6009 designs.
    May 2010
    Quote Originally Posted by OldSpark View Post
    lol :P . what i want in mind is as simple as it gets. get the unregulated 12v from car battery, and use an 5v voltage regulator (and by that i mean , a linear regulator) and just hook that 5v to the tablet DC input!.
    ofc i could also use a switcher. but my question would be the same . if i would need an ampere source as well as a voltage source. but from your answer, i assume, just hooking 5v to the tablet (etc if there existed a 5v battery) , will charge it. correct?
    Raw Wave
    Nov 2009
    "i would need an ampere source as well as a voltage source" - I think that is your problem....
    You need a 5V power source (converters, regulators, etc) that is capable of delivering 2A (or more).
    So a 78S05 or LT1085 (set to 5V) or their low current 7805 or LM317 version with transistor current boosters.
    May 2012
    Grandville, MI
    Just make sure your circuit is designed to handle Automotive voltages. Some Regulators are designed for in car use and others are not. You can also add protection circuits to your regulator to protect it from over voltages, spikes and other nasty things that can happen in your car.
    May 2010
    cool. do you have any kind of such protection circuit in mind??
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    I am sure you could get away with this little gem http://uk.farnell.com/murata-power-s...?ref=lookahead it's only 1.5amp but I think most manufactures of power supplies and tablets build in some cushion. These run very efficient and are cool to the touch SNO
    May 2010
    why buy something you can make?? so a 5v Regulated DC, with more than 2Amp output will be enough? (if i make a 5v 5A, i wont burn anything, correct? :P )
    Raw Wave
    Nov 2009
    Why make something when you can buy it cheaper. better, smaller.... ???!
    Did you make the PC you are writing your replies on? You can - after all, the original IBM PC used all "off the shelf" components so that anyone could repair it. Mind you, it cost $7,000 in the 1980s. And BTW - do IBM still make PCs?
    You have noise issue because of your philosophy.
    Go ahead, make your own dc-dc converter or ancient regulator.
    You ask if 5A (at 5V) won't burn anything, yet you try to tech me stuff?
    (Yeah, I think it's time I bug out....)
    May 2010
    yep
  1. Dodge Charger Tablet Project
    By Lando in forum Android Tablet
    Last Post: 11-10-2012, 06:00 PM
  2. DC-DC in car laptop charger
    By Wozza in forum How to Power a Laptop
    Last Post: 06-07-2012, 09:27 PM
  3. usb car charger?
    By Transamsfast in forum General Hardware Discussion
    Last Post: 01-09-2007, 09:21 PM
  4. New charger?
    By boomintrac in forum General MP3Car Discussion
    Last Post: 06-24-2005, 11:29 AM
  5. Laptop + No Charger In Car; 2 PCs?
    By Fox_Mulder in forum General Hardware Discussion
    Last Post: 08-23-2004, 04:14 AM
