did you copy all of the folders before the install? you need to install from the harddrive. not the dvd. sorry my grammar sucks im typing on my pocket pc...
I copied the whole dvd to my hd, ran the setup from the hd. Now when i run the program, it says
Not sure what to do besides virtual drive.cannot find map data files
Please make sure the storage card is properly inserted or reinstall map data from dvd.
Jae
Greedy
-Adj.
Anybody who makes significantly more money than you do.
The Hoe-Puter Worklog
Progress (Phase one):
Planning:
[----------] 97.3%
Parts Aquisition:
[----------] 95%
Install:
[----------] 95%
I got mine to work. I copied the inav folder and setup folder to my c: root, ran setup from there, and it's been gravy ever since.
Jae
Can someone here let me know if I'm missing a folder in my installation directory...? I've got the same issue as some of the previous posters. I type in a destination, IG finds it, I select it, add it to favorites, but it never appears in the favorites list... The favorites list is always blank... I installed from the hard drive from a folder on the D: drive which holds a copy of all the contents of the installation DVD....
I installed to the default location on C:
This is my directory structure after installation:
C:\Program Files\iNav (empty except for the iGuidance folder below)
C:\Program Files\iNav\iGuidance (contains the program files)
C:\Program Files\iNav\iGuidance\Snd (contains .wav files)
Is there some directory missing in which saved Favorites and Home data get stored? No matter what I do, I can't save Favorites or Home info...
'01
Hang on while I defragment my car...
the Acura ITX project
the Acura ITX skin for RoadRunner
project progress: 99%
favorites and such are stored ing the C:\iNav iGuidance directory
favorites.dat
home.dat
recent.dat
itinerary.dat
TruckPC - gutted, being used for test setup
BoatPC - off season - Inelmac screen needs serviced again!
BlazerPC - last vehicle PC I'll build
Ok... is your IG being installed in
or
C:\Program Files\iNav iGuidance
Are those .dat files just text files? For some reason mine aren't being created and I can't figure out why... I just now created those 4 files in the iGuidance directory and tried to save an address as a favorite and nothing... I've uninstalled and reinstalled twice now, exact same behavior each time, which is to say, none.
'01
iGuidance gets installed into c:\program files\iNav\iGuidance
favorites are stored into another directory created when you load maps c:\iNav iGuidance
The installation may be a bit confusing, but just try to follow the included installation instructions, step-by-step. It will work.
Yeah after several uninstalls/reinstalls I managed to get it running properly and saving Favorites/Home data... I couldn't, however, get it to run from a virtual drive mounted through Alcohol 120%. Whenever I try that it goes back to not saving Favorites again. But that's ok, at least it's running and not taking any more space on the HDD than it would have as a mounted ISO.
'01
after searching, i found this thread.......but its not helping so im bring it back up...
i have mounted n installed my IG but it wont also save. what am i missing? i tried creating the "iNavi iGuidance" folder in C but that didnt work.
