Page 1 of 4 1234 LastLast
Results 1 to 10 of 40
Thread: Iguidance 4.0
    Mar 2007
    Iguidance 4.0
    1st problem setting my home address is giving me problems, I enter info and it finds my location. I click save. I click on home and nothing is set. Same applies to favorites nothing is saved. Lastly I would like to load all the map read instructions still didnt understand. I know we can create simulated drive or I believe it called virtual drive to do the same thing. I have been searching around and Ive learn so much from this forum. Any help would be great. pc xp pro service pack 2 sx270
    Mar 2007
    i was able to get it working.
    Jul 2005
    how? I am having this problem too
    Variable Bitrate Uraijit's Avatar
    Aug 2007
    Utah
    When you get a problem fixed, it's common courtesy to share what you did to get it working. Otherwise you're just wasting bandwidth...
    Greedy
    -Adj.
    Anybody who makes significantly more money than you do.
    The Hoe-Puter Worklog
    Progress (Phase one):
    Planning:
    [----------] 97.3%
    Parts Aquisition:
    [----------] 95%
    Install:
    [----------] 95%
    Mar 2006
    Colorado, but Canadian!
    Mmmmmmmmmmmmmmmmmmm.... Bandwith......
    1.9in x 2.9in -- 47mm x 73mm
    Aug 2007
    I am having the same problem. Would you share what your solution was please?
    Mar 2007
    LOL
    i can't believe he's not sharing the info either.
    it's the least we can do to contribute to the community.
    Maximum Bitrate tn6478's Avatar
    Jun 2006
    Houston, TX
    Quote Originally Posted by ggcr View Post
    You guys should not have problem setting those up. To set up home location all you have to do is click set home and type in your home location and it should save. Same as all route that you go to. It should be in recent and if you want to save the location just set as favorite. If you have problems with it most likely because Inav the main program is install in the wrong location. If you are using ewf install the main program on the c: drive and then put the main onto the extended partition. Iguidance 4 should read it and all you favorite and stuff will be save.
    Aug 2007
    Fixed mine, I didn't have all the folders installed correctly. Initial install missed one of them. Thanks
    Jan 2007
    before you install iguidance, copy the cd onto your hard drive. install it from that folder not the cd.
  1. VMWare Fusion can't run iGuidance 4.0
    By pip in forum MacCar
    Last Post: 09-26-2007, 10:01 AM
  2. iGuidance 4.0 and RR?
    By Outsider787 in forum Road Runner
    Last Post: 08-13-2007, 02:24 PM
  3. Replies: 17
    Last Post: 06-15-2006, 01:46 AM
  4. iGuidance Font Size Fix summary thread
    By Viscouse in forum GPS
    Last Post: 03-28-2006, 07:21 PM
  5. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
