Results 1 to 10 of 10
Thread: Iguidance 4.0 With RR
    Constant Bitrate funkyphil's Avatar
    Sep 2007
    CHI-TOWN
    Unhappy Iguidance 4.0 With RR
    Ok so here is my problem, I had my INAV working just fine for about three or 4 months. But now for some reason it will not connect to any GPS sat, and if it does for some reason it loses the connection. If it doesn't lose the connection and i go put in a destination it says "LOOKING FOR GPS SIGNAL" then just freezes!
    What is going on? everything else works fine on my system. Any Ideas?
    Thanks Phil
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    If you have your COM port set over 9 it will crash. That's the only known issue that I am aware of causing symptoms you describe.
    Sep 2007
    CHI-TOWN
    yes I was thinking about that, My port is set to two. and i am using xport for rr and i have that set to 3 and 4. So what I tried today was changing my port in rr to read 4 not three, and changing the Iguidance to read 4 not three. Seems to be working now, however i didn't go driving much today. I did an update on my roadrunner and i am thinking that might of screw things up maybe? We'll see, thanks a lot for your imput. I'll keep you and everone else up to speed if that fixes the problem.
    Thanks Phil
    May 2006
    Calgary, Alberta
    Are you running xPort3? There's 2 other things that cause mine to take its sweet *** time. If I boot my computer with the GPS receiver plugged in, let it hibernate, unplug the receiver, then come out of hibernation without the receiver plugged in, it gets all confused. So no matter how many times I plug it back in, it won't recognize it until I reboot with it plugged in. The other is when I have to drive through my parkade first, for some reason it gets confused and does nothing for about 5 minutes after I get out on the road.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    I have had the same problem very recently. Any other GPS program with my Holux213U Works fine. All of a sudden IG4 (after working perfectly for 5 months) will not lock at all..?? This happened 3 weeks ago and I messed up my commands in SIRF DEMO utilty and ended up having to crak open my unit and Short it out for reset. After that is ran great gain up until today...Only problem is in Iguidance of course... I do not know....
    Nov 2007
    PA
    Well... Here's "my" deal. I got it working.... I really do not understand this but here it goes.
    I have had my Holux GPS Magnetic mouse mounted on the exterior of my vehicle. I noticed after getting it to work on my Desktop that when I stuck it to my car it immediately lost signal..? As soon as I picked it off the metal it grabbed 8 Sats??? And metal / magnetic surface I attached this to it stopped working? So, it is meant to be both magnetic and weather proof. I gave up and placed it in my back cargo area on Plastic where it is doing just fine. I have no idea what or why this is but I am glad it isn't totally shot.
    Jul 2008
    I have been having a similar problem. When I start up iGuidance by itself with the gps adapter already plugged in it detects the adapter and grabs the sats. If I start up RR with the adapter plugged in, I have to unplug the adapter and then plug it back in to get a sat signal. Even in the new version (2009) I still have this problem. I noticed someone talking about setting their com ports in iGuidance and RR differently. Is there something I'm missing. I have the adapter on com port 4 and that is what I have RR looking for the gps on too. Please help.
    Nov 2007
    PA
    Quote Originally Posted by kemaa View Post
    iguidance and RR use the GPS signal for two different things. RR uses it for elevation etc... Iguidance for the Navigation. Lets say your "windows assigned" com port for your gps is 5. Then in iguidance alone setting it to 5 would be fine. But if you plan to allocate the GPS for features in RR as well aside from iguidance you need to split the port with something like Xport. It takes your COM 5 IN, and you output it to 2 ports of your choice. Let's say 6 and 7. Then you set iguidance to use port 6 and RR to use 7. You cannot set RR and Iguidance to use port 5 at same time, you need to split them.
    Variable Bitrate Wayne613's Avatar
    Apr 2009
    Delaware
    Quote Originally Posted by Dougw133 View Post
    Old post reply, but thanks. That answered the other "I'm not sure, but I think it's that" question I had. Meh, comm port sharing. I hated that in the legacy computer days, you'd think it'd be long gone by now.
    Jun 2008
    Which com port being greater than nine is the issue? The windows assigned port or the one I'm splitting with xport and sending to iguidance? I've got 14 as the windows port and splitting to 20 and 21 for dfx and iguidance respectively. It's been working for the longest time but just in the past day or two I've been having issues where I'm using gps and it will just lose signal as though I'd unplugged the gps antenna and the only way to get it to work again for either gps or the dfx compass is to reboot the pc. I was wondering if the antenna was starting to fail. I also am having it where Iguidance will just freeze a few moments after I start it, and restarting gps jut has it freeze again. For this I also have to reboot it once or twice to vet it working. I'm actually off on a roadtrip in co right now so I'm really limited in the research and debugging I can do. (forums via a smartphone suck!). So if anyone could offer suggestions on these problems you'd be a real lifesaver. I hate papr maps
  1. iGuidance Route Lists in RR
    By Jaguar77 in forum GPS
    Last Post: 09-01-2007, 07:20 AM
  2. RR , Iguidance, and Xport3
    By Custommx3 in forum Road Runner
    Last Post: 08-28-2007, 01:51 PM
  3. Replies: 12
    Last Post: 03-21-2007, 11:34 AM
  4. Custom log parsing automation…
    By xcntrk75 in forum Software & Software Development
    Last Post: 05-11-2005, 03:19 PM
  5. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
