Results 1 to 3 of 3
Thread: iguidance not working with MTK gps
    Jun 2008
    MA
    Hi,
    I just installed my first CarPC, and I have some trouble getting GPS working. I have a 32 channel MTK USB gps thingy. It gets installed as a serial port. It has a test application (Heavensea something or other) and when I run that it seems to be doing something, i see a lot of satellites and whatever.
    But with iGuidance 4 nothing happens. It basically starts up with an address where I was earlier (probably when I last ran the test program), and it doesn't update at all. There are no errors or anything. The port settings are correct.
    Any ideas what might be happening? Should i try to run both the test application and iGuidance at the same time with XPort or something?
    Thanks!
    Edit: It was a configuration problem, Centrafuse's Nav was also opening the port even though I wasn't using it (and have no maps for it). It works now!
    Jan 2008
    Norton, MA
    good to see it is working for ya.
    BTW where abouts in MA are you? I am in Norton, MA bout 5 minutes up the road from the Comcast Center (formerly Tweeter Center.)
    2005 Ford F-350 crew cab 4x4 6.0L SRW LWB
    Planning:
    [|||||||||-] 95%
    Parts Aquisition:
    [||||||----] 60%
    Install:
    [|||||||||-] 90%
    Finally getting Built
    Jun 2008
    MA
    Cool, I'm in cambridge (boston)
  1. Replies: 0
    Last Post: 07-16-2008, 07:07 PM
  2. Replies: 0
    Last Post: 05-26-2008, 02:51 PM
  3. Replies: 17
    Last Post: 06-15-2006, 01:46 AM
  4. iGuidance and gps question
    By Yevmeister in forum GPS
    Last Post: 03-13-2006, 11:51 PM
