Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: iGuidance "Can't install Windows Service"
  1. #11
    FLAC WuNgUn's Avatar
    Sep 2007
    Quote Originally Posted by Injector View Post
    i was just about to mention that, as well as using a live bart pe cd to install windows from a live enviroment
    I think I tried a PE CD on it before, and it wouldn't start either! lol
  2. #12
    Sep 2007
    Quote Originally Posted by blk02si View Post
    I've been running iGuidance on vista x64 for some time without issue. If your PC is blue screening at all you have serious issues with the OS layer, which should be fixed before attempting application installs.
    Blue Screen is during XP install...not when working from the OS.
  3. #13
    Elsewhere
    Rather than KillDisk I have a suggestion that may help your XP install experience and take far less time.
    Install XP as normal, but when it comes to the point in the install where you format the HDD, do a FULL format.
    When you do a quick format, the disk is not checked for errors and bad clusters aren't noted and written around. A quick format only creates a partition table and nothing more.
    The full format does the actual disk check and will work around unusable areas of the HDD.
    Now, if you DID do a full format, what is preventing you from simply purchasing another HDD for the CarPC and/or the OS? HDDs are cheap these days.
    How about the Wiki?
  4. #14
    Maximum Bitrate Injector's Avatar
    Mar 2005
    Rockledge, FL
    i'm not familiar with your setup but i know some dell pcs doe the same thing, when installing xp when the setup starts to detect drives it blue screens because in the bios raid was turned on even tho not raid was configured, does your mobo have raid built in.
  5. #15
    Sep 2007
    Quote Originally Posted by DarquePervert View Post
    It doesn't make it that far...blue screens when it tries to detect the HDD's...
  6. #16
    Sep 2007
    Been there, tried that! lol
    It does have SATA RAID, but the BIOS setting has ALWAYS been set to SATA as IDE...
  7. #17
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    The BIOS could also have "Boot from other devices" enabled, or something like USB drives. May as well disable every device you can (and remember what those were) and worry about them later.
  8. #18
    Sep 2007
    I think I'm going to stick with Vista for now...
    I disabled regular IDE interface (tried enabled too), and disabled boot from other device...
    Also disabled boot sector protection and everything else I could think of...
    I even tried a regular IDE drive....same blue screen
  9. #19
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Have you tried a different disk in order to rule out failing hardware?
  10. #20
    Sep 2007
    Yeah, put a regular IDE, 320GB drive in it, and got the same blue screen during install...
    Very frustrating...
  1. Windows XP LAN Boot install – no floppy or CD-ROM
    By Zip-Lock in forum Software & Software Development
    Last Post: 10-20-2008, 01:29 AM
  2. Replies: 3
    Last Post: 12-23-2007, 08:39 AM
  3. Replies: 11
    Last Post: 05-25-2006, 12:58 AM
  4. install windows 95 in 4.47mb
    By churnopol in forum Software & Software Development
    Last Post: 09-30-2003, 07:36 AM
  5. windows install
    By Stine161 in forum Software & Software Development
    Last Post: 09-21-2002, 11:43 AM
