Results 1 to 10 of 20
Thread: iGuidance "Can't install Windows Service"
    FLAC WuNgUn's Avatar
    Sep 2007
    Anyone get this in Vista?? Never seen it before, and actually, never had a problem before this install...
    What's the deal?
    TIA
    Sep 2007
    Anyone? I gotta have nav!!
    Maximum Bitrate Injector's Avatar
    Mar 2005
    Rockledge, FL
    do yourself a favor, loose vista
    Sep 2007
    Quote Originally Posted by Injector View Post
    I wish I could!!
    XP will not install on my HDD...gets a blue screen before it shows me the HDD's...
    It's SATA, so I nLited the drivers into setup...no go.
    Mounted the HDD in my desktop, and presto...installs!
    Plug it back ito the car, and blue-screen...
    Been thru the BIOS...
    Been thru drivers...
    Been thru different install disks...
    Been thru a zillion partition utilities...
    Wiped it clean...
    FixMBR
    FixBOOT
    Ever since I installed W7, XP will not go back on that drive
    Sep 2007
    Running iGO now...
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Which version of iGuidance?
    And as far as loading xp... have you tried Killdisk? Zero out the drive completely? It did run XP once upon a time right?
    Tidder
    Try RevFE
    Mar 2005
    Rockledge, FL
    Quote Originally Posted by Tidder View Post
    i was just about to mention that, as well as using a live bart pe cd to install windows from a live enviroment
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    I've been running iGuidance on vista x64 for some time without issue. If your PC is blue screening at all you have serious issues with the OS layer, which should be fixed before attempting application installs.
    Sep 2003
    New Mexico, USA
    Are you running the install of iguidance as administrator? (Right click, run as admin or something)
    Tidder
    Try RevFE
    Sep 2007
    Version 4
    KillDisk huh? 500GB worth of zeroing...what'll that take, 3 or 4 days? lol
    I'll keep it in mind...
    So far Vista is working okay and iGO is working okay. Only issue I'm having is with the CF TPMS messing up CF. The 2.0.0.8 version runs a little better, but it causes CF to hang when resuming...
    The latest version causes CF to become unresponsive at times.
    What bothers me is, I can install XP to the same 1/2TB drive from my desktop PC perfectly fine!! Only when the drive is connected to the MS-7191 does it behave like this...
    Damn ATI chipset!
  1. Windows XP LAN Boot install – no floppy or CD-ROM
    By Zip-Lock in forum Software & Software Development
    Last Post: 10-20-2008, 01:29 AM
  2. Replies: 3
    Last Post: 12-23-2007, 08:39 AM
  3. Replies: 11
    Last Post: 05-25-2006, 12:58 AM
  4. install windows 95 in 4.47mb
    By churnopol in forum Software & Software Development
    Last Post: 09-30-2003, 07:36 AM
  5. windows install
    By Stine161 in forum Software & Software Development
    Last Post: 09-21-2002, 11:43 AM
