Results 1 to 10 of 14
Thread: Iguidance and com port issues.
    Maximum Bitrate stonestatue's Avatar
    Feb 2006
    Huntsville, AL (Atlanta, GA temporarily)
    I am trying to configure Iguidance 4.0 to work with my BU-353 GPS receiver. I changed the com port of the Serial to USB bridge a few times and it worked at first.
    Iguidance seemed to default to com port 1, so I assigned the GPS receiver com port 1. Once I did this, it stopped working. It just stays on the last location it picked up. I tried changing the com port in Device Manager and in Iguidance but to no avail.
    I started MS Streets and Trips and chose the com port assigned to the GPS receiver, and it worked. This leads me to believe it's a software or configuration issue with Iguidance and hopefully an easy fix. Any ideas?
    Check out my GMC Savana worklog.
    Remaining tasks to facilitate vanputer installation codename "Enterprise":
    - Edit skin to liking.
    - Get compatible phone for mobilephone.net.
    - Facilitate HVAC control.
    Dec 2008
    make sure you have the latest driver from globalstats website. are you using xport? if not, you pretty much need to. just the fact that streets and trips might have still been in control of the gps while you tried iguidance might be part of it
    Feb 2006
    Alright, I tried Xport. It seems to just indicate which com port each device uses, unless I missed something.
    Maximum Bitrate bratnetwork's Avatar
    Oct 2007
    Haledon, NJ
    choose the port at the top that the GPS reciever is (dont worry about the list at the bottom) then click enable, then in the open boxes below select the ports you want it to output
    (sorry its not real descriptive... i dont have it in front of me, just going off memory)
    Oct 2007
    Haledon, NJ
    i also have a slight issue with iGuidance 4 with the com port.... i have xPort sending it out to ports 10 and 11 (10 for RR, 11 for iG) and sometimes when i run iG it works, and sometimes it goes back to port 1 and i have to input port 11.... works but is annoying at times... not sure why but ive been too busy / lazy to trouble shoot it yet.
    Variable Bitrate TeamRSX's Avatar
    Nov 2007
    Ottawa, Ontario
    Quote Originally Posted by stonestatue View Post
    Xport works great. Its purpose is to split the port up so multiple applications (ie. rr and iguidance) can use the port.
    You put the input as the actual port that the gps uses in device manager, if your using windows. Then you can specify the output ports that your applications can use.
    For example, i connect my gps and in my device manager its assigned as com3. Then in xport, as my input port i would put com3 (i think it will automatically detect the port too), then in my output ports i can use any that aren't in use so they are not being stolen from another application. So, in my output ports i can assign com4,com5. So, in this case if i was using riderunner and iguidance i would assign those output ports to those applications, so that riderunner and iguidance can both use the ports. Make sense?
    Feb 2006
    I uninstalled Microsoft Street and Trips as well as the USB to Serial driver that came with the GPS on the installation disk. I downloaded and installed the driver from GlobalSat's website just in case it's a later version than the disk. Then I restarted.
    Now when I use Xport, it won't even detect the GPS. I also tried to manually select the com port assigned to it in the Device Manager, but it isn't listed in the available com ports in the drop down input com ports list. Device Manager assigned com 4, but 4 isn't listed.
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    iGuidance will only remember 1 digit port numbers. Use something lower than 10.
    @stonestatue Uninstall the driver that doesn't work. Install the one that does.
    May 2006
    Calgary, Alberta
    Ya, I think there's some sort of issue with using COM ports above 7, try and use something lower. And don't use xPort3 when troubleshooting, it just adds an extra layer of something that could be broken. Turn it off and just try and pick up the right port in the GPS application. Once you have that working, then get xPort3 working after.
    And always have the latest driver, iGuidance wouldn't pick up my receiver neither until I installed the right driver.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    FLAC Marvin Hlavac's Avatar
    May 2005
    In iGuidance, beside the com port setting, make also sure to set the correct baud rate. Alternatively, use the "auto detect" feature of iGuidance to find your GPS receiver.
