Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Iguidance Volume issues
  1. #11
    May 2006
    Calgary, Alberta
    And this is happening when running iGuidance outside Road Runner?
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
  2. #12
    Mar 2005
    Quote Originally Posted by hpric View Post
    That is exactly what happens. The only time the volume level is normal is when I close everything and actually click on the sound file from within the iGuidance sound folder, any other time the volume is through the roof.
    Sorry but that doesn't make any sense. You must be confused about something. No matter what you do to volume if the system volume is low nothing loud can come through. Therefore the only possible answer is that it is changing the system volume somehow.
  3. #13
    Jan 2006
    Quote Originally Posted by sxott View Post
    and yet that is exactly whats happening. The only time I can control the Iguidance volume is when I click on the actual sound file. PC volume down, winamp volume down, Iguidance volume down to one bar still = Super loud iguidance voice prompts.
  4. #14
    May 2006
    Calgary, Alberta
    Are you using SPDIF? This will ignore your Windows volume slider since it's digital and it's either on or off.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
  5. #15
    Jan 2006
    Quote Originally Posted by Maheriano View Post
    I'm using this card and wouldn't the SPDIf affect all volume not just Iguidance?
    http://us.creative.com/products/prod...=17751&listby=
  6. #16
    Jan 2006
    Winamp volume up, windows & Iguidance volume all the way down and still I get yelled at by Iguidance. I also notice that it is also amplifying the music as well when the prompts come on. I checked in RR Config and played with the "Lower volume to %" checked the box and unchecked it and still get the same results. I'm fresh out of ideas...I just leave iguidance on mute
  7. #17
    May 2006
    Calgary, Alberta
    plug in headphones to the onboard audio jack and see if it does the same thing.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
  8. #18
    Jan 2006
    ok, I had to install winxp again so everything is fresh. Testing the system on my desk and the GPS sounds fine. Installed in the car and I'm having the same issue. The only difference was on my desk I had the speakers connected to the headphone jack of the sound card instead of the RCA's. Gonna try and connect back to the headphone jack and see if it changes anything. Will post results shortly
  9. #19
    Jan 2006
    ok, that did nothing, Iguidance is stll loud
  10. #20
    May 2006
    Calgary, Alberta
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
  1. Replies: 570
    Last Post: 11-05-2009, 03:49 PM
  2. Replies: 12
    Last Post: 07-31-2007, 02:05 PM
  3. Road Runner Volume Issues ! ! !
    By rewindnottm in forum Road Runner
    Last Post: 03-20-2007, 04:38 AM
  4. iGuidance file issues.
    By seanz0rz in forum GPS
    Last Post: 02-25-2006, 12:59 PM
  5. iGuidance and Frodoplayer display issues?
    By wallaceacura in forum Software & Software Development
    Last Post: 07-16-2005, 02:09 AM
