Geez no one has any idea? The files sound fine on my home pc but in the car they come through at full blast
I'm hoping someone could help me out here. I have the volume in iguidance V4 set all the way down to where it only shows one bar and its still extremely loud. I'm not sure what is going on here but it wasn't doing this before in my old pc. I'm using an external soundblaster card but I don't think that has anything to do with it. Anyone have any ideas?
I've tried playing around with the volume line in RR config but still the same and its driving me nucking futts
Are you using it in RR? If so there is a seperate setting for volume in RR.ini (editable in RRConfig)
it happens in both cases with RR and stand along, However if I go to the iguidance folder and actually click on one of the sound files it comes through perfectly. Bur when the program is running the sound is amplified to a point where I have to mute it altogether. If I have my music playing loud then the iguidance volume doesn't come through as loud as when there is no music playing
Happens to me sometimes too, you got to play with all the volumes:
Winamp
Windows
iGuidance
You probably have the Winamp volume way down meaning you have to turn up the volume in Windows (RoadRunner) to nearly full blast. Then even that one little bar in iGuidance is going to be loud as hell.
Try decreasing the Windows volume and increasing the Winamp volume by actually opening Winamp and adjusting the volume in its GUI. That does it for me.
Ampie Case
256 MB DDR2 PC5400
Xenarc 700TSV - VGA Monitor
Intel D945GCLF Motherboard
M2-ATX-HV
2005 Honda Civic
I have and still can't figure it out. I've even uninstalled and reinstalled IG just to make sure and stil![]()
Ampie Case
256 MB DDR2 PC5400
M2-ATX-HV
2005 Honda Civic
That is exactly what happens. The only time the volume level is normal is when I close everything and actually click on the sound file from within the iGuidance sound folder, any other time the volume is through the roof.
What are your mixer settings like?
Nope, I think I've tried everything, (pc volume, winamp volume, soundcard mixer volume and iGuidance volume all the way down and still the voice prompts are loud. The only time it comes through a tad lower is when I have music playing at a loud level and I get nice normal level when I manually click the sound file within the iguidance sound folder
