Results 1 to 4 of 4
Thread: Iguidance V.2011 wont run after install
    May 2010
    I installed the new version of iguidance v2011 on my Windows 7 64bit computer after removing a working copy of v4 and rebooted. After the install all seemed to work perfect till I double-clicked on the icon to start it and got the following error:
    Problem signature:
    Problem Event Name: BEX
    Application Name: iGuidanceNPC.exe
    Application Version: 3.0.0.0
    Application Timestamp: 4cd91ab1
    Fault Module Name: iGuidanceNPC.exe
    Fault Module Version: 3.0.0.0
    Fault Module Timestamp: 4cd91ab1
    Exception Offset: 0011edb4
    Exception Code: c000000d
    Exception Data: 00000000
    OS Version: 6.1.7600.2.0.0.256.1
    Locale ID: 1033
    Additional Information 1: 5748
    Additional Information 2: 5748c74f961c02f8fdea54d25d631c63
    Additional Information 3: 7511
    Additional Information 4: 751194d52c45a6a220a84cddd3e441d3
    Read our privacy statement online:
    http://go.microsoft.com/fwlink/?link...8&clcid=0x0409
    If the online privacy statement is not available, please read our privacy statement offline:
    C:\Windows\system32\en-US\erofflps.txt
    I uninstalled the program and rebooted, reinstalled it, rebooted again and the same problem after several reboots. I am not sure whats the problem with this software and could use some help. All thoughts and answers will be greatly appreciated.
    Thanks,
    Eazy
    May 2010
    can anyone help?
    Elsewhere
    The iGuidance Compatability page says that 2011 runs on Win7 after a patch.
    Have you installed this patch?
    How about the Wiki?
    May 2010
    I sent their support an e-mail and was told that there is no patch:
    Hi:
    Are you referring to v2011 evaluation? There’s no patch file available for this version as iGuidance has been tested to work w/ Windows 7 32 AND 64 bit OS w/ exception of Enterprise edition. If what you have is the Enterprise edition, then you’ll need to do the following:
    1. right-click on the iGuidance short-cut on the desktop,
    2. select "properties",
    3. select "compatibility" and set "run this program in compatibility mode for Windows XP SP3".
    Thank you.
    Support Team
    www.inavcorp.com
    I also called them and they said just do whats above and thats it..
  1. Replies: 570
    Last Post: 11-05-2009, 03:49 PM
  2. Tired of "ABC" keyboard in IGuidance? iGQwerty
    By lostreception in forum GPS
    Last Post: 09-18-2009, 06:07 PM
  3. Newbie Set on Mac Install
    By The_Blade in forum MacCar
    Last Post: 06-12-2008, 03:16 AM
  4. Replies: 11
    Last Post: 05-25-2006, 12:58 AM
  5. iGuidance 2.x auto-run shortcut
    By ziggyrama in forum GPS
    Last Post: 08-13-2005, 07:05 PM
