Results 1 to 6 of 6
Thread: Motorolla RAZR V9 Tethering?
    Maximum Bitrate LinuxRacr's Avatar
    Jul 2003
    Dallas, Texas
    Anyone tether this phone?
    I want to be able to have my Centrafuse front end connected to the internet via bluetooth and this phone.
    My Car: 2001 Mazda MP3
    My OLD Carputer project: Here
    Completion Progress Bar: [**********100%]
    Current build! Here
    Completion Progress Bar: [*********99%]
    Jan 2006
    We should probably round up some people who are on the MotoDev team. (Technically, I'm one of them, except I haven't actually done any development work since joining.)
    Java is all the rage these days, especially in mobile phones, so it's possible that a Java application can be developed to utilise the phone's Bluetooth module to connect to the car PC. It will then have to bridge the two network adapters: GPRS/3G and the Bluetooth PAN.
    Admittedly, it would be a lot easier for people who have a Windows-based phone because there is an Internet sharing application built into Windows Mobile and you can set it to share through USB or Bluetooth. This is how I plan to access the internet with my car PC ... once I actually build the car PC and once I change my rate plan
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    I have a data plan with AT&T. I then used Motorola Phone tools to use my V3xx as a bluetooth modem. I just use the MPT to configure a connection. I then copied the shortcut created by the Moto Phone Tools to the startup menu and everytime the computer starts, it connects to the internet 3g via bluetooth.
    I can't see why this would be much different with yours, but one never know.
    Jul 2003
    Dallas, Texas
    Yeah, I did the same thing, except I don't want to connect to the internet every time I boot up.
    Current build! Here
    Aug 2007
    I have tethered a v3m and a krzr in the past and it wasn't very difficult at all. Your best bet would be to check out Howard Forums.
    Jan 2005
    I have a v8 similar phone different OS uses linux however the principal is the same install Motorola phone tools and setup a internet connection with it it will create a dial up connection in network connections you can then connect or disconnect as if were a standard dial up connection
  1. Tethering and prices
    By blackcobra487 in forum Wireless Communications
    Last Post: 10-17-2008, 05:44 PM
  2. Phonecontrol via bluetooth to Razr V3
    By DaveB in forum PhoneControl
    Last Post: 05-13-2006, 12:52 AM
  3. Need help with setting up RAZR V3 with PC
    By ddotderek in forum Wireless Communications
    Last Post: 07-31-2005, 03:06 AM
