Results 11 to 20 of 22
Thread: I need a new phone, which carrier/phone intergrates the easiest?
  1. #11
    Maximum Bitrate bratnetwork's Avatar
    Oct 2007
    Haledon, NJ
    Quote Originally Posted by Goose_0007 View Post
    i have an iphone and i think i may have found the easiest way to do it with that. i take my computer everywhere with me and they get awfully boring with you dont have internet. but i can hook mine up via blue tooth or usb and the both move pretty quick. i should also add that im an avid iphone user
    Do you have the data w/ tethering plan? I use a TP2 with verizon and tether it A LOT and they don't care. But I've heard that AT&T gives people a hard time if they tether too much? I was thinking about going to AT&T so I can get the unlocked HD2 when it comes out but the whole tethering thing made me change my mind. Also with the iphone to tether you had to jailbreak it but did you also have to unlock it? Most things I've seen out there require and unlock for tethering.
    Right now I tether through my TP2 via USB or WIFI using WMWifiRouter. I haven't yet gotten to get BT phone calls and stuff working properly through the PC though.
  2. #12
    Low Bitrate nhra no 2's Avatar
    Aug 2006
    Aurora, IL
    I had t-moblie with work. My wife has at&t. Work is switching to at&t, but not keeping me on there plan. But I did talk with the at&t rep, and they can me a little bit better break on my plan, so I may be going with at&t. Any recomendations on a phone from at&t that may intergrate with my car PC some what easy?
  3. #13
    Jan 2008
    Quote Originally Posted by bratnetwork View Post
    unlocking it would allow it to work on other carriers-- jailbreaking a iphone is just so that you can use non-apple approved software, and features on it (like teathering).
    Quote Originally Posted by nhra no 2 View Post
    iphone?!?
  4. #14
    Aug 2006
    Aurora, IL
    If I jail break my new iphone that cost $200, what happens when I manage it with itunes? Will appel and/or at&t know that this has happened? I have a itouch allready, but with the how much apple and at&t try to lock down and controll there product, how do jail break it and not pis*-*ff either of them. Also how easy is it to jail break it, and how easy/hard is it not to brick it as well?
  5. #15
    Oct 2007
    Haledon, NJ
    Quote Originally Posted by soundman98 View Post
    Yes i understand this... I was looking into the iphone as i was considering to switch to AT&T (still considering) and all the programs i saw to enable tethering required jailbreaking and unlocking. I have no problems jailbreaking but i didnt want to unlock it.
  6. #16
    Jan 2010
    yeah i havent had problems with att then again im not on it a whole bunch and yes mine is unlocked as well
  7. #17
    Jan 2008
    i have a unlocked and jailbroken iphone 3g on t-mobile, but am still using 3.0 software.
    everytime you update the iphone os, you would need to re-jailbreak, and re-unlock the phone. when doing this try to remember that there is a chance that apple has closed the holes that allow you to jailbreak/unlock the device-- this has happened at least once with the 3.1 update.
    it will sync fine with itunes, just like it did before, the only difference is that software updates are more of a pain, and can't be mindlessly clicked to run(because you need to make sure that the update did not affect your ability to jailbreak/unlock the device).
    there are many sites with instuctions on jailbreaking/unlocking-- as long as you follow the instructions for your model, you shouldn't have too many problems.
  8. #18
    Nov 2006
    Any phone that uses the Android 2.0 (or greater) OS can use a software called PDA.net. It's free unless you need https access and even then, it only costs $30 I believe. It also works for Iphones but you do have to root them. I have a Motorola Droid and am using PDA net on 3G network. It connects to my phone via USB or even Bluetooth and it does it automatically. Perfect setup in my opinion.
  9. #19
    licensed to kill - FKA kev000
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    You buy the n900 unlocked, it works on TMobile or AT&T. You *own* the phone, which means you can change carriers at your option without a contract buyout (at least in theory). Did I mention you don't have to jailbreak or unlock it?
    As an added bonus, the n900 will integrate well with LinuxICE (as soon as I get mine). But you may only appreciate that if you like things that run fast and that are easy to setup and maintain :P.
    Former author of LinuxICE, nghost.
    Current author of nobdy.
  10. #20
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Quote Originally Posted by kev000 View Post
    ...But you may only appreciate that if you like things that run fast and that are easy to setup and maintain :P.
    You're joking right?
    Need to <insert>and have no working turn by turn navigation...</insert>
    Tidder
    Try RevFE
