Quote Originally Posted by Yevmeister View Post
go to device manager, see the COM port aiisgend to your gps device, you cann keep it on 1 but i would put it on 2 or 3, then in you map software GPS setting select COM you have assigned in device manager, and baud rate of 4800 then you should not have any problems
Yev
Tried it but the Window itself was not detecting the GPS device. I removed the unit from the dash and unhooked both USB line to Blue tooth radio and Sprint USB antenna. I rebooted few times with nothing attached. Then attached the GPS antenna. Finally, Windows detected it, as well as StreetDeck. Thank you all for the support!
