Results 1 to 10 of 11
Thread: Infill T3 GPS not working
    Feb 2007
    CA
    I just installed Infill T3 in my car with StreetDeck. The computer is not detecting the GPS on Com 1. Can someone from mp3car.com help me?
    I ran Sirf Info program and even before StreetDeck is run, the computer is saying "No Device" on COM 1. I've deleted the driver many times and tried deleting the entire COM 1 port many times too.
    Also, before I bought the unit, I specifically asked mp3car.com if the GPS was Sirf III, and they said yes. But according to the model# on the bottom of the GPS antenna (X-150), it seems to be Sirf II.
    Elsewhere
    You really should be posting these issues in the Bug Reports forum.
    Are you certain the GPS is connected to COM1? Check in the Windoze Device Manager.
    How about the Wiki?
    _
    Mar 2004
    Little Elm, Texas
    When did you buy this unit and from where?
    If you boought this unit as hardware only or off of the ebay auction, please do not expect any form of support from the store as this was part of the terms of the sale.
    Jan Bennett
    StreetDeck Staff
    Jun 2006
    Columbia, MD.
    The T3 has had problems in the past on detection of the GPS (something to do with the 9 pin mini din coonection). Manually put it on com1 and save the settings. You should be fine.
    Feb 2007
    CA
    Quote Originally Posted by RedGTiVR6 View Post
    Purchased from store.mp3car.com.
    Order date: February 14, 2007
    Order#: 19256
    Received on February 21, 2007
    Didn't have time to install until recently.
    Infill T3 with Infill Station
    2007 Hyundai Sonata
    Feb 2007
    CA
    Quote Originally Posted by DarquePervert View Post
    There's only one PS/2 connector that comes out of the unit, with "GPS" sticker on it. The window itself is not detecting the unit. Device manager shows COM 1-9. I've uninstalled Sprint Novatel drivers and the program. Thinking maybe StreetDeck was confusing with Sprint Novatel drivers as it uses three COM ports, one which is for GPS. So I uninstalled every COM ports, rebooted few times, and left only with COM 1. Still no device found.
    2007 Hyundai Sonata
    _
    Mar 2004
    Little Elm, Texas
    Have you tried what mpacesaints suggested? Manually setting it?
    Please let us know!
    Jan Bennett
    Feb 2007
    CA
    Quote Originally Posted by mpacesaints View Post
    What do you mean by manually putting on COM1? Do you mean opening the unit and making a direct connection to the board?
    Or manually manipulating the settings from the windows? But GPSinfo program should be detecting the device on COM1. Currently the Windows device manager only shows COM 1. Do I need to change the port settings like baud rate?
    2007 Hyundai Sonata
    Maximum Bitrate Yevmeister's Avatar
    Nov 2005
    Chicago
    go to device manager, see the COM port aiisgend to your gps device, you cann keep it on 1 but i would put it on 2 or 3, then in you map software GPS setting select COM you have assigned in device manager, and baud rate of 4800 then you should not have any problems
    Yev
    R. T. F. M
    StreetDeck Staff
    Jun 2006
    Columbia, MD.
  1. Infill T3 with Streetdeck
    By irdrive in forum StreetDeck
    Last Post: 04-09-2007, 12:11 PM
  2. infill t3
    By isamfarina in forum Centrafuse
    Last Post: 04-09-2007, 10:46 AM
  3. Infill T3 in the UK: Some questions
    By discopanda in forum Newbie
    Last Post: 10-14-2006, 07:50 AM
  4. Infill T3 with Streetdeck wiring
    By terrygold in forum StreetDeck
    Last Post: 09-24-2006, 02:40 PM
  5. MapMonkey Gps working but not on map
    By BOND007BE in forum Map Monkey
    Last Post: 03-11-2005, 10:02 AM
